Old 11-12-2013, 02:36 PM   #1
Rugged Brown's Avatar
Batteries providing 120V
I was just offered a stack of 12 v batteries that can provide 120v. They came out of a portable X Ray machine. Should I ? This should start some interesting conversation.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 11-12-2013, 02:51 PM   #2
Dave_Monica's Avatar
Hmmm...are there 10 - 12V batteries wired in series or are they wired in parallel powering a inverter?
Dave
Old 11-12-2013, 03:25 PM   #3
Why would you need that much battery power?
Note that it's direct current, not the AC that you get off of a power grid. The only think you could do with them is to put them into a parallel configuration (giving you 12v) so that you could power an inverter, or any other 12v apparatus for a considerable length of time.
The down side is that then you have to charge them.
Old 11-12-2013, 03:31 PM   #4
The biggest down side would be the weight, approx. 400+ lbs.
Old 11-13-2013, 07:18 AM   #5
Herk7769's Avatar
What is the AH rating and size of the batteries?
This may be "doable" for a home "off grid" installation, but most likely not practical for a mobile one even if they are small (like a motorcycle battery).
HAM CALLSIGN - KC3FFW
Old 11-13-2013, 07:28 AM   #6
Oakman's Avatar
It sounds to me like someone is trying to get rid of some old used batteries to avoid paying a disposal fee. I'd pass.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 11-13-2013, 07:52 AM   #7
dcheatwood's Avatar
These may be considerably smaller than reg deep cycle batteries as they were basically backup power for radiology equip intended for short term use. But still, the space and weight and bother of trying to keep them charged. And are they so old they won't hold a charge? Need more info. If price was right, and quality was good, and a/h was right, it might be ok to do and only use 2 in parallel. ???
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 11-13-2013, 08:15 AM   #8
KMP44's Avatar
It does sound like maybe that is the case. However, he might be able to turn the table on them - the scrap value of lead has really gone up lately. I had to scrap a huge 36v forklift battery at work a few months ago and had people fighting over who could take it our hands...
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 11-13-2013, 09:36 AM   #9
dcheatwood's Avatar
Good idea!
Old 11-13-2013, 02:53 PM   #10
RPAspey's Avatar
There are 120vdc to 120vac inverters. So, if the batteries are in good shape, and of high enough capacity, you might be onto the start of an emergency power back up system. For your home of course. I suspect that the batteries would be too heavy for all but the biggest RVs. We use 150AHr-130VDC at work, and that 52 cell lead-acid battery set weighs a lot!
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
battery
