Old 08-18-2016, 08:45 AM   #1
Battery
I have a 2017 22RR toy hauler. Pretty well versed about batteries just looking for your ideas/ways you do things. I have the factory installed deep cycle that lasts a few days at most with light use. This is my first trailer so I don't know how people go about basic housekeeping regarding their battery. I have mine plugged into 120v A/C all the time. I was thinking this may not be a good thing and wondered what you do to keep the battery from being drawn down?
I was considering:
1. Putting a wing nut on the negative post to allow me to easily remove the negative battery cable when not in use.
2. Wiring in a second battery, or just keeping a charged spare up front.
uchytil is offline   Reply With Quote
Old 08-18-2016, 08:54 AM   #2
Herk7769's Avatar
A couple of days for a "OEM" battery is pretty good.
They are usually Group 24 Dual Purpose "Marine Type" Batteries around 75 Amp Hours.
When you replace it, you will do yourself a favor by getting a "true" deep cycle battery as large as will fit in the space available.
Having a shutoff is always a great idea and so is recharging it whenever the "Good" light on your monitor goes out (about 50% discharged).
LOTS of great reading here on deep cycle battery care and feeding so I won't go into depth. I attached some light reading.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
ID:	117676   Click image for larger version
Name:	Battery Display.jpg
ID:	117678   Click image for larger version
ID:	117681   Click image for larger version
File Type: pdf How to correctly interconnect multiple batteries to form one larger bank.pdf (106.1 KB, 12 views)
HAM CALLSIGN - KC3FFW
Old 08-18-2016, 08:55 AM   #3
I have 2 batteries installed wired in parallel. I have a wing nut, that I do just as you describe, and remove the negative wire when not in use. This has worked well for me in the last year and a half I have owned it.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-18-2016, 09:08 AM   #4
Herk7769's Avatar
As an FYI, you can use the battery capacity vs discharge rate chart "as a percent" to calculate the actual capacity of your battery's amp hour ratiing.
For example if your battery has 75 AH, use that as 100% in the chart.
At 12.5 amps of continuous discharge, for example, a fully charged 75 AH battery will last 70% of its 20 hour rating at 5 amps (or 14 hours).
This is why folks add multiple 12 volt batteries so in a 2 battery "bank" each (correctly wired) battery will see only 1/2 of the total system demand therby extending the useful life of the bank in addition to the "doubling" of rated capacity.
battery
