12v dc system not responding from battery alone although when shore power is plugged in everything worked as advertised all fuses/ circuit breakers are good , checked inline 12 v dc circuit breakers in battery compartment first one didn’t reset second one seemed okay not sure could it be a problem with the 12v dc cutoff switch? Not sure when I had shore power plugged in that the converter was charging battery.
