Old 09-07-2013, 06:06 PM   #11
Denver, CO
garbonz's Avatar
If the battery is bad, and you replaced it, I'd still evaluate the converter since you may just kill the new battery by using a bad converter. Use a digital multimeter to check the voltage when the camper is plugged in as TRIGUY suggests
2017 Fuse 23T
Old 09-07-2013, 06:48 PM   #12
caper's Avatar
If you charged the battery up and everything is working then the battery is not bad. You most likely have a bad converter. It is not charging the battery and not delivering 12 volts when plugged into shore power. Before replacing the battery have your local battery shop do a load test on the battery to see if it is bad and has to be replaced. Do not want you to spend money on a battery if the converter is the problem.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
battery
