Old 09-06-2013, 10:54 PM   #1
Battery
Will a bad battery cause lights to dim and ac t stat problem even though I am hooked up to electric power?
Joe William is offline   Reply With Quote
Old 09-07-2013, 01:02 AM   #2
PPST OGCDG
Frank-VA's Avatar
Yes and also converter will cause a problem. The AC T Stat uses 12 volt.
I had all three changed out this summer. {AC T Stat, Converter and Battery.}
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 09-07-2013, 01:45 AM   #3
Easy way to find out is to disconnect the battery. Since you're hooked up to electric AC power, your converter should power all 12V systems. If there is still 12V issues, the converter needs attention.
SCOC is offline   Reply With Quote
Old 09-07-2013, 06:30 AM   #4
TURBS's Avatar
I'd recommend a progressive dynamics brand converter if yours is bad.
Normally the reason it goes bright and dim is its overheating lights dim then when it cools it comes back on lights brite.
Also you don't need to replace whole distribution center either.
Old 09-07-2013, 07:17 AM   #5
TURBS's Avatar
Converter removed in photo.
There's also a wfco converter trouble shooting guide in the Library section here on frf.
Turbs
Old 09-07-2013, 07:39 AM   #6
Triguy's Avatar
My first thought was also a bad converter.
You didn't explain why the battery is bad, but the converter should be charging it. Its pretty easy to test the converter output voltage, which should read about 13.6 volts. Here is a link to the converter manuals that Turbo mentioned.
Forest River Forums - Downloads - Power and Electrical
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-07-2013, 10:06 AM   #7
Battery
It looks like a bad battery may be the problem. I hooked up a charger last night. Everything seems to be working today. I am replacing battery today.
Old 09-07-2013, 11:32 AM   #8
Fire Instructor's Avatar
If you do ANY amount of camping without hookups, I would HIGHLY recommend a pair of 6-volt golf cart batteries to replace the single 12v battery. You will get MUCH better use from it. I got mine at Sam's Club at a very reasonable price.... If you only camp with hookups, it probably isn't worth doing....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 09-07-2013, 12:22 PM   #9
Battery
Interesting theory. Why do you have to have a charged battery to run digital thermostat even though I have the battery disconnect on?
Old 09-07-2013, 05:40 PM   #10
bikendan's Avatar
all the digital thermostats that i've seen, needs a AA or AAA battery to function.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
battery
