Old 07-10-2015, 09:33 AM   #11
Batts-toy's Avatar
Originally Posted by CJM View Post
We I stalled a solar system. In a customers RV earlier this year. . He has 520watts of solar, PWM charge controller and 4, 121 ah 12 volt batteries, 3000 Watt inverter..... . He runs his ac with it
I recently installed 300 watts solar and 2500 watt inverter with auto transfer switch, but as per my last post batteries are lacking but I have no plans to run AC's off them anyway.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-12-2015, 08:10 AM   #12
CJM pretty much nailed it. I was a battery distributor once upon a time and quality of construction separates the good, the bad, and the ugly. Everyone uses the same materials; lead, sulfuric acid, trace elements, water. There is no magic potion involved. The more lead/electrolyte available for chemical reaction, the more electric current will be produced. We had a saying regarding choosing a superior battery-Buy your batteries by the pound.
pjnlorrie is offline   Reply With Quote
Old 07-12-2015, 07:50 PM   #13
I can't afford $750 per battery, I can afford 4 Trojans and they will fit in the compartment
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 07-12-2015, 07:52 PM   #14
CJM
Not my point at all. . All I was saying, is that even though I have some of the best 6 volt batteries out there, there is no advantage 6 volt vs. 12 volt batteries. 6 volt is not better that 12 volt, just because it is 6.
CJM is offline   Reply With Quote
Old 07-12-2015, 10:23 PM   #15
Just out of curiosity how long would he be able to run his ac with it? 10-15 minutes!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 07-12-2015, 10:49 PM   #16
CJM
2-3 hours actually. I was quite surprised my self. I would never sell a system as being able to do that, but they figured they would try. Worked great. The biggest problem is recovery time and solar output. There is enough power in the system, but you drain it down a lot and need to let it recover. That being said, if you need to turn it on foe 15, just to cool it down, it will do that, and still have lots of reserve left
battery
