Originally Posted by A32Deuce
Check converter fuse and by accident was bat. switch turned off or bumped?
Why - yes it was!
And it happens to be in a very inconvenient location:
- Near the floor, right by the bathroom where people walk all the time
- When the slide is 'in', one cannot reach the disconnect. (OTOH, if one disconnects it, then the slide is stuck 'out'.)
- If it is bumped, it will always be bumped to the 'off' setting, never the 'on'
Any harm in just cutting it off with a hacksaw once I have first turned the circuit on? There's a little tab that prevents the key from being pulled out, but the key itself is just plastic. I already have my own separate battery disconnect by the battery box, so I don't really need the factory option.
