Old 07-15-2013, 12:02 PM   #1
Battery and 30Amp Fuse
Somebody told me that all I had to do was pull the 30Amp fuse that is located a couple of feet from the battery and that would disconnect all power to the trailer. I did that and the next time I opened up the trailer, the battery was dead. Is this not the correct way to do a battery disconnect?
Signed, Newbie Craig
Sandblaster is offline   Reply With Quote
Old 07-15-2013, 12:25 PM   #2
Herk7769's Avatar
That fuse was most likely to a slide.
The "battery fuse" is an automatic reset fuse that looks like this and has to be disassembled (battery wire removed) to disconnect the battery.
HAM CALLSIGN - KC3FFW
Old 07-15-2013, 12:28 PM   #3
TURBS's Avatar
Only way to disable all power to camper is remove battery cable or install a battery disconnect switch.
Turbs
