Old 04-19-2015, 09:59 AM   #1
Battery & converter upgrade on new Wildcat Maxx
We're picking up a new Wildcat Maxx 29bhs next week and first on the list is installing more/better/bigger batteries and a converter upgrade. I was thinking about a pair of Interstate 6v's or Trojan T105's (both available locally) but any suggestions for a converter upgrade?
I'd like to keep the trailer plugged in pretty much all the time to run a Davis air-dryer.
We dry camp about 50% of the time and I'll be charging the batteries with my generator as needed.
Thanks for any tips or suggestions.
Farmer is offline   Reply With Quote
Old 04-19-2015, 11:57 PM   #2
Originally Posted by Farmer View Post
... first on the list is installing more/better/bigger batteries ... . I was thinking about a pair of Interstate 6v's or Trojan T105's (both available locally)...
If you'll have only two batteries, consider that 2 6-volt batteries in series may be electrically more efficient but leaves you with no redundancy. If you have 2 12-volt batteries in parallel you can take one of them out of the bank in case of failure, and still have 12 volts. You can't do that with only 2 6-volt batteries.
Sent from my phone using Tapatalk.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 04-20-2015, 11:10 PM   #3
Hadn't thought about 12v's but I feel pretty comfortable with the 6v's. The decent quality ones (interstate or trojan) are pretty reliable and readily available in case of the failure.
Old 04-20-2015, 11:19 PM   #4
TURBS's Avatar
I recommend a progressive dynamics converter upgrade!
And a progressive industries hardwired ems surge guard.
"Two separate companies"
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-21-2015, 06:53 AM   #5
Turbs, is that converter programmable to match the charge specs of the battery manufacturer? Or is it simply more intelligent and possibly higher-powered than the stock converter?
- 2000 Coleman Mesa
Old 04-21-2015, 06:59 AM   #6
TURBS's Avatar
Not sure I've seen a rv converter that is programmable per user spec, however it is the most "intelligent" converter system I've seen or used.
http://www.progressivedyn.com/power_...ters_9200.html
http://www.progressivedyn.com/charge_wizard.html
Check out the "new" interactive videos.
My wfco is now 4 years old, I'm buying a progressive this week so I can install before our first trip.
TURBS
battery, cat, converter, upgrade, wildcat
