Old 04-04-2015, 08:49 AM   #11
I would suggest checking each 12 v fuse with an ohm meter. My Rockwood has two reverse polarity 40 A orange fuses and my slide has a 25 or 30 amp fuse at the bottom of the the stack of 12 v fuses. Not intending to insult you on meter use vs visual. I would also encourage you to take a volt meter to see if you have 12 volts coming off the converter by removing one of your fuses and putting the test light or meter on one of the two terminals. If no 12 volts there then flip all your 110 V breakers one at a time. One of those operates the converter itself. From there you may need to slide the converter out and start checking other things. Disconnect power first before you do this and exercise great caution as there are a lot of exposed hazards in that converter.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-04-2015, 08:56 AM   #12
On second read it does look like you are getting power to your 12v side while plugged to shore. Can you slide your converter out and check for 12V coming in? Of course, unplug from shore and make sure battery is attached. Do you have a battery disconnect switch?
TST 507RV TPMS
Old 04-04-2015, 09:04 AM   #13
I agree with Batts-toy on circuit breaker failure. A meter will instantly tell you this. The contacts eventually corrode inside and the replacement cost is minimal. You can purchase one at an automotive supply like Auto Zone, Oreilly's etc. Take that little silver mini breaker with you. They are usually 25-30 amp. Clean all the wire terminals with sand paper until shiny and then install them back onto that mini-breaker. You might be surprised what a corroded terminal can do, including blow a fuse!
TST 507RV TPMS
Old 04-04-2015, 03:16 PM   #14
Thanks to all who responded. Some of the info has helped me locate unfamiliar trailer secrets, i.e. the hidden fuse at the tongue which seems to be the main fuse controlling power from battery. Never knew it was there. In the end, a young friend, very well read mechanical and electrical genius, came over and discovered a big part of my problem was I had pushed in the battery shot off button (I had it in and out trying to solve things) and did not reset it. All 12 volt problems amazingly solved. Now I am testing and checking the slide motor connections as slide now works but for how long, as this is how this saga started. One thing we noticed is that there is a column of fuses in the converter, to the left of that column there are two fuses, one 40 the other 30 amps. I am thinking those should be the same, likely 30. Aanyhow, thanks for all your help.
CAMINO2012 is offline   Reply With Quote
Old 04-04-2015, 04:19 PM   #15
Cam- Glad you found the issue. There are many knowledgeable people to help you. I have referenced this site many times for the invaluable resources of so many others. It sounds like those two fuses to the left are your reverse polarity fuses, one for neg and one for positive side. If so, they should match. Check your schematic or for a panel label. Mine are 40 amp each. I would also pick up some spares of each size to have on hand. Thanks for letting us know the ending story. Happy Camping!
TST 507RV TPMS
Old 04-05-2015, 07:47 AM   #16
Make sure battery disconnect switch is fully pulled out...mine has two steps...two cicuits...caused similar type problem...limited power
jimmyhof24 is offline   Reply With Quote
Old 04-05-2015, 07:55 AM   #17
bubbles's Avatar
Sometimes operator error is a good thing; gets you into the inner workings of how systems actually interconnect and function for when an actual failure occurs.
battery, power
