Old 04-03-2015, 03:27 PM   #1
Battery and power problem
I have a 2014 Rockwood UltraLite 2104s. Used it all last season (April-Oct) with no problem. Over winter we kept it plugged in and had a small thermostat controlled heater in the coach.
When we de-winterized, we found the power awning worked but the slide did not. Note that these coaches are advertised to have a mechanical bypass for slide operation. This coach has what looks like an incomplete bypass panel in the bin at left front near the water pump. It lacks buttons and lights as far as I can tell.
I found a burned out 40 amp fuse and replaced it. Thereafter no battery power in coach, even when I switched coach battery for fully charge RV battery. In short system does not seem to charge battery and none of the 12 volt systems work when coach is not plugged in to shore power. Even while plugged in, though power awning works slide does not, yet fuses are all okay. There is supposed to be another fuse in that bypass panel, I don't see it. Any ideas?
CAMINO2012 is offline   Reply With Quote
Old 04-03-2015, 03:55 PM   #2
fonzie's Avatar
Look underneath trailer near front tongue for a mini-breaker and press black button to reset. Follow positive lead from battery. Hope that will fix your issue.
Fonzie
Old 04-03-2015, 05:26 PM   #3
Thanks Fonzie. I found the mini breaker, the fuse was good. That is the one I had understood was in the compartment above. I also found the little black button, but pushing it did no good, did not reset anything. The button was very easy, no resistance and no clicking or anything. Should I be opening the silver junction box or taking apart the connection with the black button?
Old 04-03-2015, 08:05 PM   #4
Newbie
Camino, mine is a 2015. Has a manual crank on the entry door side of the trailer, located just above the dual wheels on the frame. Should be a handle in the trailer to fit the crank nut. Not sure why you are not getting power to the slide though.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
Old 04-03-2015, 08:27 PM   #5
Cam, did you check both the breakers and dc fuses in the main panel? If you had a 40 amp fuse blow, that indicates a ground or faulty connection somewhere. I have found that sometiimes the breakers trip and they only way you can reset is to flip them off and back on even though they appear to be "on".
magpi26 is offline   Reply With Quote
Old 04-03-2015, 09:52 PM   #6
Thanks. Yes I did check the breakers a couple of times as have that same experience that you cannot really be sure otherwise. I am looking for a short, have found some blackening near underneath tongue fuse, but so far nothing loose or bad contact.
Old 04-03-2015, 10:26 PM   #7
Hang in there.
Cam, my best wishes and sure hope you tell us how you solve this one.
Old 04-04-2015, 09:25 AM   #8
mrmichael's Avatar
I think the 40a fuses are reverse polarity fuses? Is your battery hooked up correctly?
2014 Rockwood 2109S
2013 F-150
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is online now   Reply With Quote
Old 04-04-2015, 09:26 AM   #9
mrmichael's Avatar
The slide on my 2109s is fused with a 30a fuse under the tounge of the trailer ( near where A frame meets the body
2014 Rockwood 2109S
2013 F-150
Other Motorhome
Old 04-04-2015, 09:44 AM   #10
Batts-toy's Avatar
Are you using a volt meter in your search, a meter will tell you exactly where the power stops flowing. Sometimes the breaker with the black button totally fails and must be replaced.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
battery, power
