Old 11-16-2012, 09:57 AM   #11
Hob
I think somewhere in the RV manufacturer manual is an oath they sign and send back to the RV gods that is designed to keep up guessing.
My volt/ohm meter is my best friend when working any electric issue in my TT. I also tag any wire I work with when I find where it comes from and goes to in the trailer. I use a white paper tag with a string in it for that purpose.
Hob is offline   Reply With Quote
Old 11-16-2012, 12:52 PM   #12
TURBS's Avatar
Originally Posted by DAISY BOYKIN View Post
The Ole Coot should know, I understand he had the line moved south of him!
HE MOVED IT HIMSELF !
Old 11-16-2012, 01:01 PM   #13
Moved it to the MO-IA line when I lived in MO. There is a reason why all the trees in north Mo lean to the north.
Old 11-16-2012, 02:54 PM   #14
wmtire's Avatar
Originally Posted by MillerTime View Post
Interesting, I wonder if the 110 is color coded like the 12 volt or if it is opposite like most home wiring? Never thought much about it on my rv.
I always figured they color coded the rv's more like in AC home wiring, since the rv's plugged into AC.
It seems like that would cut down on the confusion (especially with all the dual AC/DC powered stuff in an RV), more so than if you used part of the color codes for DC wiring, then part of the color codes for AC wiring.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-16-2012, 03:16 PM   #15
DAISY BOYKIN's Avatar
My forest river product------------
My Forest River product (ROCKWOOD) 12VDC positive + wire is yellow with a green stripe, the negative - is solid white. But it is better to use a VOLT meter to determine which is POSITIVE and which is NEGATIVE.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 11-16-2012, 03:33 PM   #16
VinceU's Avatar
In accordance with Coachmen schematics Red is always the predominate supply feeders. After connection to bus or devices they may take out many colors to carry the + signals. They use white as return to ground on all devices I sighted. Auto Batteries are always red + and black ground.
Household is Red and Black 110 feeders for 220V, with white neutral returns. Most 110 feeds in household is black feed and whte returns.
Old 11-16-2012, 04:05 PM   #17
110 and 12 volts color codes are different. Even 12 volt color codes are different depending on if the system is grounded or not. I have a toy hauler and it uses a negative ground and uses red (+ or hot wire) and white (- or ground wire) wires, which follows the correct color code. Newer automobiles are red (+ or hot wire) and black (- or ground wire). Some older ones were wired the opposite way (not good). Here is a link to the US National Electrical Code (NEC) color chart that should be used. Scroll to the bottom for 12 volt systems: Wiring Color Codes : COLOR CODES I'm guessing some trailers are color coded incorrectly.
Top B is offline   Reply With Quote
Old 11-16-2012, 04:31 PM   #18
Oklahoma Proud
MillerTime's Avatar
So I guess my answer is there is no standard.
I have always used red and black as + on AC and white as -. And on all dc I have used red as + and black as - unless schematics state other wise(ie. Left right and running lamps). I have been under semi dashes and seen nothing but yellow wires- what a nightmare!
Old 11-16-2012, 05:40 PM   #19
VinceU's Avatar
Actually there really is, but loose. We said the same thing as the NEC chart US DC standard. Only just forget the positive to chassis connection, white hot. Its been since the 6V system of the 1950's its been obsolete. Gets tricky with the colors but a heck of lot easier to trace point to point through the rv.
Old 11-16-2012, 05:53 PM   #20
2003 "Wildwood" owner
In normal wiring with only a black and a white wire, the black would be the hot side. That only if there are only two wires as you described. If you don't know which one is the neutral. Use a meter and put one lead on a good frame ground and place the other on the wire. with the meter set up for continunity or ohms, you should get a reading if that wire chosen is a ground. If nothing happens on the meter try the other wire. One of them should be tied into the frame ground.
But you never know without a true schematic how it was wired by the person at the factory, so using the meter to test for the ground wire is the only way to find your answer.
retiredff2009 is offline   Reply With Quote
battery
