Old 05-31-2010, 08:33 PM   #1
Steve09's Avatar
Battery Boiling Dry ??
Hello, went camping the other day and smelled what I thought was a gas leak..turned out to be our battery was really charging, but was dry. added water but just boiled that out to. I'm going to have battery checked for a dead cell, but could something else be wrong,,oh the last 2 days I just unhooked the battery ,,seems to do good that way since I always use shore power anyway.Thanks,,,
2009 Salem La 292FKDS--7600 lbs
2006 F250 fx4 Ext Cab,Diesel
(sold)2004 F-150 5.4 Auto FX4 3.73 Gears with Factory Tow Pkg, 36 Gal Tank, 96,000 miles ,Equalizer Hitch 10000 lb Bars ,MBRP 3in Cat-Back Exhaust SI/SO
24 Days in 09, 35 Days in 10, 24 Days in 11,,23 Days camped so far in 12, 22 Days Camped in 13,,6 Days Camped in 14
Steve09 is offline   Reply With Quote
Old 05-31-2010, 09:01 PM   #2
NWJeeper's Avatar
My money is on a dead battery. They don't take well to being charged with no water in them. It's important to check them at least once a month especially if they are plugged in all the time to make sure they don't boil dry. The usual converter/chargers provided with RVs doesn't make things much better as most of them are not quality chargers.
Ed & Wendy
www.nwjeepn.com
Old 05-31-2010, 09:08 PM   #3
donjuanss's Avatar
I did that to one battery then put a battery cut off switch in place. I just disconnect the battery during long connection to shore power. works great for me.
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 05-31-2010, 09:20 PM   #4
milzat's Avatar
I second a Bad Battery. The battery could have go bad because of a bad(or poor quality) charger.
milzat is offline   Reply With Quote
Old 06-01-2010, 06:40 AM   #5
Herk7769's Avatar
Post dead battery
You still need to get that battery fixed/replaced ASAP even if you always camp with hookups. The battery also powers your emergency brakes on the camper when you tow.
HAM CALLSIGN - KC3FFW
Old 06-01-2010, 10:46 AM   #6
Steve09's Avatar
Having battery checked today,,I didn't know it helped power your emer-brake though,,I should not have left it on threw the winter,,Just came back from camping and it was fine just pluged in to shore after I unhooked one side of battery,, Can it hurt the charger if its not hooked up to battery when your pluged in to shore power? thanks
Old 06-01-2010, 12:24 PM   #7
Herk7769's Avatar
Dead Battery
The "on board" battery throws the brakes on when the breakaway pin is pulled if your camper disconnects while you are driving.
That battery NEEDS to have a pretty good charge to keep the brakes "on" hard till you can get chocks in before the battery quits.
Old 06-01-2010, 01:55 PM   #8
KyDan's Avatar
You should be ok on shore power with or without a battery.
Old 06-01-2010, 02:10 PM   #9
Herk7769's Avatar
Dead Battery
While it is true that everything in the camper (12VDC and 110 AC) will work using shore power or generator, you will still need a functional battery for driving home (except in a greater emergency like no auto stores where you are camping). Should you get stopped and checked by the troopers, without a good battery your camper will not pass inspection and you could be ticketed. IMO it is also very unsafe.
I certainly would not LEAVE home without a solid battery.
Old 06-01-2010, 05:50 PM   #10
Also, the provided converters in these campers are designed to operate with a battery. Most equipment in the camper is 12v, converted down from the converter's 120v shore power input, or generator. I believe you will eventually burn up the converter, causing an expensive replacement. I'm also for using a good battery. Randy
battery
