Old 06-14-2011, 05:30 PM   #21
HemiCab's Avatar
Will do!
Thanks Lou
HemiCab is offline   Reply With Quote
Old 06-14-2011, 08:14 PM   #22
sherdep's Avatar
Nice addition with the solar - let me know how that works out for you - I might be intrested in doing that Mod
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-19-2011, 04:59 PM   #23
On one of my old trailers my battery box had two vents on top and when it rained the water ranoff the front of the trailer on to the top of the battery box through the vents and built up inside the box. I took care of the problem by putting 2 pieces of electricins tape over the vents No more water inside the box
walker238 is offline   Reply With Quote
Old 06-19-2011, 05:32 PM   #24
after seeing pic of battery box with the solar panel i could see the vents on top of the battery box
Old 06-27-2011, 04:28 PM   #25
HemiCab's Avatar
The solar panel is keeping the battery topped off. The disconnect switch is Great!
I wanted to keep the vents open for escaping gases...the drain holes worked to keep the box empty of rain water.
Old 06-27-2011, 04:45 PM   #26
rhyno76's Avatar
Originally Posted by HemiCab View Post
OK I added the disconnect switch (Blue Sea 6006 M - front of battery box) yesterday and while I was at it I added a solar charger (top of propane cover) to maintain.
Thanks for the advice and guidance.
HC
What kind of solar charger did you buy? We're trying to find a good one to keep our battery topped off.
Ryan & Cortney
2012 Windjammer 3008w
rhyno76 is offline   Reply With Quote
Old 06-27-2011, 09:43 PM   #27
HemiCab's Avatar
Sunforce 50013 http://www.amazon.com/gp/product/B001D6GYLO
I liked the fact it connected directly to the battery unlike the model 52013.
Old 06-27-2011, 11:12 PM   #28
Herk7769's Avatar
The only reason the 1 watt solar charger is keeping a charge is your battery shutoff switch. At 83 milliamps of charge in full sun it will just barely replace the current loss due to internal resistance in the battery thereby keeping the battery "topped off" as you stated.
Since the Propane detector uses 100 milliamps of power when the battery is left connected there will still be a net loss of power over time (especially since the propane detector runs 24/7 and the sun does not).
Dead battery will just be measured in weeks instead of days.
For a new installation a 10-15 watt panel would be a better choice along with a battery disconnect. That would keep the battery "ready for camping" longer.
NOTE: What these small panels will not do is charge your battery if it was discharged at all to start with.
HAM CALLSIGN - KC3FFW
Old 06-28-2011, 08:07 AM   #29
rhyno76's Avatar
Originally Posted by herk7769 View Post
...For a new installation a 10-15 watt panel would be a better choice along with a battery disconnect. That would keep the battery "ready for camping" longer.
Thanks for the tip, Lou!
Ryan & Cortney
battery
