Old 05-08-2016, 11:04 AM   #1
JD57's Avatar
Battery box wiring hole
Thinking of adding an inverter in my storage box beside my battery box. Can someone please suggest/recommend best sealant compound for wiring hole that will be waterproof/dust proof but still give me the needed flexibility?
2016/15 Sunseeker 3050DS-CD
JD57 is offline   Reply With Quote
Old 05-08-2016, 11:16 AM   #2
Flybob's Avatar
Unless it is a very small inverter, you may not want to put it in a sealed box as they generate quite a bit of heat when operating. If possible installing inside the RV itself might be a better option.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-08-2016, 11:29 AM   #3
JD57's Avatar
I had seen this installation pictured and thought it was very clean looking. I was then going to wire the on/off switch and plugin at the bottom of my control area beside the battery box (hidden in one of the stair boxes) the inverter is a 1500 w and my storage space is about 17" deep by 12" h X 30" long. I thought the space would handle any heat generated.Click image for larger version
Name:	ImageUploadedByForest River Forums1462724898.877285.jpg
ID:	107237Click image for larger version
Name:	ImageUploadedByForest River Forums1462724913.016097.jpg
ID:	107238 appreciate your comments
Old 05-08-2016, 11:34 AM   #4
Flybob's Avatar
That should work well. I envisioned the storage box as a much smaller area.
TST Tire Monitors
2 100W solar panels
Old 05-08-2016, 11:38 AM   #5
JD57's Avatar
The black "gook" in the picture looks like some type of "acoustical" caulk used in home building, have you used something similar?
Old 05-09-2016, 11:34 AM   #6
Tom48's Avatar
Plain old silicone sets soft and yet in much less messy and can be removed clean if ever needed.
Tom48 is offline   Reply With Quote
Old 05-09-2016, 11:36 AM   #7
JD57's Avatar
Thanks Tom will try it as soon as I start my project in a couple of weeks!
Old 05-09-2016, 03:01 PM   #8
I have mine mounted on back wall of our 5er in front storage....Used only for the "beer" fridge in transit in summer weather
Jim in Halifax is online now   Reply With Quote
battery, wiring
