Old 03-26-2015, 02:00 PM   #11
B47
Originally Posted by edcronin01 View Post
I had a similar issue I use vice grips, I'd crimp then move it to another spot and crimp again. Also an auto parts store should be able to do that since they make up battery cables.
Vice grips or pliers might be a temporary fix,but they only crimp 2 sides of the connection.
The proper crimp tool crimps the connection 360 degrees.
Old 03-26-2015, 02:43 PM   #12
mark0224's Avatar
I would say the same as the others with one addition, slip a piece of shrink tube over the wire solder the end on the wire then pull the shrink tube down over the soldered wire after it has cooled. Us a lighter very carefully to shrink the tube be careful not to melt a hole in it.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 03-26-2015, 03:06 PM   #13
What good will the shrink tube do with the bolt exposed they all connect to?
Old 03-26-2015, 03:08 PM   #14
TURBS's Avatar
I'd remove the plastic crap to and solder.
Old 03-26-2015, 03:11 PM   #15
Fulltime family RVer
So, here's the deal with that... I own a soldering iron but I've literally never soldered.
Old 03-26-2015, 03:13 PM   #16
mark0224's Avatar
More or less a neatness and no sharp edges.
Old 03-26-2015, 03:17 PM   #17
No time like the present to learn. Get some rosin core solder and start teaching yourself. DO NOT GET ACID CORE for electrical work. Heat the terminal and flow the solder into the end of the wires until it wicks to the insulation. Do not melt the insulation, might want a wet rag to immediately cool the connection and insulation.
Old 03-26-2015, 03:17 PM   #18
TURBS's Avatar
I used to hate soldering.
After doing quite a bit at work I actually do not mind it and actually prefer to do it that way then another method even if it takes longer.
Biggest key in my mind is to make sure you've heated the wire and connection well before a ply solder.
Some times a mini butane torch works better.
Practice a bit .
Old 03-26-2015, 03:58 PM   #19
On the bright-side, I have rosin-core sided.
When you say insulation- you mean the outside white covering that is stripped away?
Old 03-26-2015, 03:58 PM   #20
Practice a bit .
Don't own a torch...
battery, led
