Old 03-26-2015, 04:08 PM   #21
Kaadk's Avatar
On the bright-side, I have rosin-core sided.
When you say insulation- you mean the outside white covering that is stripped away?
Attachment 72261
Yes. The cover over the metal part of the wire is the insulation.
As far as soldering, what you do is use the iron to heat the metal part of the wire. Then, touch the solder to the hot metal.
I've seen too many people try to put the solder on the iron and then try to get it onto the wire (like painting with a brush). That part don't work.
And, when all else fails, youtube it!
There's no use crying over spilt milk, unless it's on your keyboard.
Old 03-26-2015, 04:08 PM   #22
Attachment 72261
If that is the soldering iron( in background of pic) you plan on using to solder that ground wire, forget it!! you will need larger watt gun, at least 1000 watt
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-26-2015, 04:16 PM   #23
Fulltime family RVer
I would have!
And yes, that's the soldering iron. That's actually why I included it in the background- hoping to illicit feedback on it.
Old 03-26-2015, 04:20 PM   #24
Yes. The cover over the metal part of the wire is the insulation...]
Not what I meant, the cover on the terminal should be cut off to solder. I was referring to the white plastic insulation on the wire itself.
I agree, the 60W iron is too small.
Old 03-26-2015, 04:24 PM   #25
Ok, so I'm back to going to an autoparts store and asking them to re-crimp this wire or buying a whole new one.
Old 03-27-2015, 07:33 AM   #26
pfeather1's Avatar
And please don't use a torch around a battery - it could explode with drastic results
pfeather1 is offline   Reply With Quote
Old 03-27-2015, 07:45 AM   #27
OR, just buy a crimping tool and re-crimp it and then buy a 1000W soldering iron and solder it. It's called learning to DIY! That's how we all had to learn.
Old 03-27-2015, 07:46 AM   #28
It's just the cost of tools are killing me! $20 here, $50 there add up...
Plus now I have to pack everything away for either storage or into the camper for our big trip.
Old 03-27-2015, 07:49 AM   #29
A crimping tool is relatively inexpensive and not any bigger than a pr of pliers and the soldering iron is not large or expensive and the good part is you can use them over and over ... and not depend on someone else, plus, once you buy them, you don't even have to feed them.
Old 03-27-2015, 07:53 AM   #30
TURBS's Avatar
X2
battery, led
