03-26-2015, 04:08 PM
#21
Originally Posted by ependydad
On the bright-side, I have rosin-core sided.
When you say insulation- you mean the outside white covering that is stripped away?
Attachment 72261
Yes. The cover over the metal part of the wire is the insulation.
As far as soldering, what you do is use the iron to heat the metal part of the wire. Then, touch the solder to the hot metal.
I've seen too many people try to put the solder on the iron and then try to get it onto the wire (like painting with a brush). That part don't work.
And, when all else fails, youtube it!
#22
Attachment 72261
If that is the soldering iron( in background of pic) you plan on using to solder that ground wire, forget it!! you will need larger watt gun, at least 1000 watt
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
03-26-2015, 04:16 PM
#23
Always Learning
I would have!
And yes, that's the soldering iron. That's actually why I included it in the background- hoping to illicit feedback on it.
03-26-2015, 04:20 PM
#24
Yes. The cover over the metal part of the wire is the insulation...]
Not what I meant, the cover on the terminal should be cut off to solder. I was referring to the white plastic insulation on the wire itself.
I agree, the 60W iron is too small.
03-26-2015, 04:24 PM
#25
Always Learning
Ok, so I'm back to going to an autoparts store and asking them to re-crimp this wire or buying a whole new one.
03-27-2015, 07:33 AM
#26
And please don't use a torch around a battery - it could explode with drastic results
03-27-2015, 07:45 AM
#27
OR, just buy a crimping tool and re-crimp it and then buy a 1000W soldering iron and solder it. It's called learning to DIY! That's how we all had to learn.
03-27-2015, 07:46 AM
#28
Always Learning
It's just the cost of tools are killing me! $20 here, $50 there add up...
Plus now I have to pack everything away for either storage or into the camper for our big trip.
03-27-2015, 07:49 AM
#29
A crimping tool is relatively inexpensive and not any bigger than a pr of pliers and the soldering iron is not large or expensive and the good part is you can use them over and over ... and not depend on someone else, plus, once you buy them, you don't even have to feed them.
03-27-2015, 07:53 AM
#30
X2
03-27-2015, 07:54 AM
#31
Now you know why oc's trailer is filled to the gills!
03-27-2015, 07:56 AM
#32
And what happens when the next one pulls out or another wire comes loose when you are out on the road somewhere? I have a small kit with connectors and crimping tool cost 10.00 bucks ( not highest quality but will get you back on the road) and about the size of large hard cover book just in case.
2014 Forester 3051s
2012 Sonic toad
03-27-2015, 08:02 AM
#33
And towed with a weak kneed 5.4L Chevy.
03-27-2015, 08:56 AM
#34
One thing nobody has mentioned yet.. while you are at it I would check the surrounding wires and connections to see if any of the others are loose as well. Get it all done now to avoid headaches later. IMO
2015 Cedar Creek 38CK
03-27-2015, 09:10 AM
#35
See post #9
03-28-2015, 04:39 AM
#36
See post #9
SORRY... Guess I'm a day late and a dollar short
03-28-2015, 05:34 AM
#37
Nothing to be afraid of, this is a 5minute fix
2006 Roo 23B hybrid
2006 Ford F150 4.6L
04-07-2015, 02:36 PM
#38
Always Learning
Well, I took the simple route and my father-in-law just recrimped the wire onto the connector. It looks like it didn't get a great crimp to start and is holding pretty firmly now. I already had an uber cheap crimping tool. Part of it is my laziness - the camper was at storage and I'd have to bring the camper home in order to have 120v to plug in a soldering iron (which also would need purchased).
If it causes me problems again, I'll get a properly sized soldering iron and fix them up right.
04-07-2015, 02:40 PM
#39
If you use the proper crimping tool and properly prepare the wire by stripping the right amount of insulation off of it,you should not need to do any soldering.
04-08-2015, 05:44 AM
#40
I respectfully disagree with the above statement. Soldering in effect "tins" the wire. . Which gives MUCH greater resistance to corrosion. When I use tinned wire on marine electrical I can fix it and forget about it.
2015 274 RK LIMITED <'{{{{><
