Old 03-26-2015, 01:08 AM   #1
Fulltime family RVer
(-) battery cable pulled out
How do I fix this? This white wire goes from the battery to the negative ground on the camper wall.
Here it is out:
Here is me holding it back in so my 12v would work after j disconnected from the truck:
Old 03-26-2015, 03:52 AM   #2
More info please: Did it pull out because there wasn't enough slack in the wire or was it yanked out? How is it attached to the wall; soldered or with a nut? Is that blue fitting a crimp type fitting?
If that is a crimp fitting and there is enough slack in the wire to get back in there, you can use pliers to force the crimp open a little and then add a little solder to the fitting. If it is just held on with a nut, then get a new crimp fitting and maybe a little solder or heat shrink tubing over it.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 03-26-2015, 04:45 AM   #3
RPAspey's Avatar
Thats a nylon insulated crimp lug aka.StaCon. Get yourself a crimper from just about any store that has hardware and some lugs as you may need another at a later date so get a variety. Remove the bolt to the stacked crimps, match the old one to a new crime, insert wire into the new crimp, place crimp into tool and squeeze the handle. Re-install. Really is that simple. Get the tool and crimp lugs as you'll likely need one in the future for something else.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-26-2015, 05:59 AM   #4
BiigDaddy's Avatar
X2
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 03-26-2015, 06:11 AM   #5
fonzie's Avatar
X3
Fonzie
Old 03-26-2015, 07:44 AM   #6
First, here is what the second picture should have been:
Second, sounds like this isn't hard if I have the right tool.
Third, I am not sure when it came out. My bet is that it came out when I last installed my battery; as I was lowering it, the cable got under the battery and pulled it down. I didn't think anything of it at the time.
It is connected to the wall with a screw- I'm guessing a self-tapping one. Looks like there are 4 or 5 different cables grounding at that same spot.
Old 03-26-2015, 11:55 AM   #7
camaraderie's Avatar
This link will give you the items you need.
Ratcheting Crimping Tool
Cheaper crimpers will make cheap crimps that eventually fall apart. This is a modest one that will serve occasional needs well.
I'm also looking at where all those wires come together and thinking you need a cleaner solution. Something like this bus bar would help keep things orderly and traceable in the future and give you a solid connection to the coach for each wire.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 03-26-2015, 12:05 PM   #8
My 2014 CC 29RE had same problem....FR did not crimp the terminal at factory....I took it off and went to my local electrical Co and they crimped it properly and soldered the cable before hand!!!.....QC @ FR??????? j
Jim in Halifax is offline   Reply With Quote
Old 03-26-2015, 12:13 PM   #9
I would remove all 3 or 4 of them, remove the plastic sleeve and solder them. The plastic sleeve in that location does nothing.
Old 03-26-2015, 01:54 PM   #10
I had a similar issue I use vice grips, I'd crimp then move it to another spot and crimp again. Also an auto parts store should be able to do that since they make up battery cables.
edcronin01 is offline   Reply With Quote
battery, led
