Old 09-04-2014, 05:35 PM   #1
Battery cable type for dual setup?
Hi all
I'm going to install a second 12 volt battery on our Wildwood 21RBS, and I'm just wondering what size (guage) and type of cable I should be using to hook up the second one?
Many thanks!
thumperpaul is offline   Reply With Quote
Old 09-04-2014, 05:42 PM   #2
I assume you are looking for a simple parallel install to double available amperage and keep 12 volts. If so, simple short battery cables in the 2,4,6,8 range are available at most parts stores for short money. Just make sure you go positive to positive and negative to negative. Our local autozone carries cables with ends for top terminal, and stud style. Most likely you have top and studs meaning you can just buy short say 10 inch cables with rings on each end, add them to the existing studs and connect to the new studs... cake!
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 09-07-2014, 09:56 PM   #3
Originally Posted by thumperpaul View Post
Hi all
Many thanks!
When I parallelled mine I used #10 Black and White (since they are in the same box)...
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
battery
