08-27-2018, 10:34 PM
Battery charger fan
Not sure what's going on here???
That's being pretty weird.
I've been living in our trailer for the last three weeks while working out of town for a bit. It's been plugged into shore power for the whole time. Never heard it do this before.
https://youtu.be/B0ry_2Acg60
08-27-2018, 10:40 PM
Just figured out there's two of them, and they're doing the exact same thing in tandem, so doubtful it's an issue with the fan.
08-27-2018, 10:53 PM
that is certainly odd. I'm assuming there is a thermostat that controls those fans so perhaps it is malfunctioning. Are you seeing any power fluctuations or anything in the trailer?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
08-27-2018, 11:07 PM
Nope, everything is working awesome sauce
08-28-2018, 01:35 AM
Should be the converter fan trying cool it down from it trying to charge bad batteries.
08-28-2018, 02:38 AM
Just a member
The fan on our WFCO converter will occasionally fire up for no apparent reason, even with the batteries disconnected. If I turn all the lights out, it will quit. Turn the lights back on and it's quiet. Could be just a sensitive creature...
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
08-28-2018, 08:52 AM
Citrus County, Fl.
On the WFCO converter the fan is controlled by DC amp draw. On the Progressive Dynamics it is controlled by temperature. With the WFCO roughly 3 amps would be low speed, 5-9 draw medium and 12-15 high. This is why you seldom hear the fans come on with a Progressive Dynamics converter.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
08-28-2018, 08:57 AM
How do you tell what type of converter it is! The fan power cords go back to a digital board, so the whole thing appears to be digitally controled
08-28-2018, 09:22 AM
Citrus County, Fl.
Open the door on your distribution panel and it will give you the name and model number. When I had my Flagstaff TT the fan would come on often and I found it very annoying. I have yet to hear the fan on my Progressive Dynamics.
99 Terry 31G
08-28-2018, 09:30 AM
Ok, well.... Right of the bat I guess this sticker on the outside tells me what I have [emoji23][emoji23]
Is this a good unit then?? It's been trouble free since we bought the trailer new in '14
08-28-2018, 10:06 AM
Citrus County, Fl.
You will get hundreds of opinions on the WFCO. I would estimate at least 80% of the Forest River products use them so the percentage of failures is probably low. It is made in China and the Progressive is made in the U.S.
The Progressive Dynamics, in my opinion, is a better converter, mainly because it is a 4 stage which seems to help prevent the batteries from sulfating and you can select the charging modes. And of course it is quieter.
99 Terry 31G
08-28-2018, 12:09 PM
Check the batteries condition. Best would be with a hydrometer.
08-28-2018, 01:39 PM
X2
The batteries could be failing and the converter is trying to keep them charged.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
08-28-2018, 01:52 PM
Originally Posted by boondocking
X2
These two (at least) guys are right. I had this issue and the battery tested OK at Wal*Mart BUT the hydrometer showed the battery had failed. New battery solved this "running fan" issue. This is not necessarily a converter issue.
08-28-2018, 02:07 PM
Batteries are brand new two months ago, 2X 6 volt
