Old 04-02-2016, 09:32 PM   #11
davel1971's Avatar
Originally Posted by boondocking View Post
IMO if you are going to spend $80-$90 on a 2 amp battery maintainer to use at home through the winter. Why not spend another $30-$40 and buy a 20-30 amp battery charger with engine start. Way more versatile.
A battery maintainer is a good option if your RV is in storage with access to power over the winter.
2 amp battery tenders are no where near $80-90. $23.30 for a Battery Tender from Amazon. Leaving the batteries on a charger is more likely to cause damage. A 2 amp maintainer will never hurt them.
David & Lynn
Old 04-02-2016, 10:24 PM   #12
@ davel1971
2 amp Battery Tender $80 - check the link below.
Didn't say to leave it on all the time.
Another alternative is buy a smart charger and once a month put it on the batteries for 24 hours.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-02-2016, 10:45 PM   #13
I swap my BatteryMINDer between my trailer battery and my tractor battery every few weeks over the winter.
2011 Traverse LT, 3.6L, FWD
Old 04-02-2016, 10:51 PM   #14
JudiVan n Gus
judivan's Avatar
Again, Thanks to you all... I didn't want to start any arguments or hate and discontent.
I take all suggestions into consideration. I will hopefully be able to make an intelligent and informed decision with your help and input...
JudiVan
Gus = 5.5lb Maltipoo lap puppy
2006 F250 Turbo 6.0
2016 FR Heritage Glen
It's not where you go in life, it's who you have with you that matters
judivan is offline   Reply With Quote
Old 04-03-2016, 12:22 PM   #15
I use the Optima Digital 400. Works on all 12v batteries. Standard, deep cycle, and fiberglass mat. Computer control conditions batteries, and won't overcharge.
http://www.amazon.com/Optima-Digital...ma+digital+400
CA62Mini is offline   Reply With Quote
Old 04-03-2016, 02:20 PM   #16
A good check on any of the tender minders is to check the voltage at the batteries after they have been on charge for a day. Voltage should not be above about 13.5 volts for long term charge. Some cheap units I have found charge over 14 volts and this can cause battery problems. A digital voltmeter is needed to see what is happening with batteries
Harkerr is offline   Reply With Quote
Old 04-03-2016, 02:25 PM   #17
I have one of these I use to keep my dump trailer battery topped up.
Works well.
opie is offline   Reply With Quote
Old 04-03-2016, 05:54 PM   #18
camaraderie's Avatar
After putting a FULL charge on your DUAL PURPOSE GROUP 24 75 amp hour sealed wet cells...you may simply DISCONNECT the negative wire in place in either the coach or the workbench and you will lose about 10% of your charge EACH MONTH at room temperature...15-20% in summer heat in the coach. Much less than 10% in the winter.
This means you can leave the batteries disconnected and uncharging...safest.... for at least 90 days without affecting your battery life cycles AND the subsequent bulk charge mode will be better for desulfation than a continuous 1 or 2 amp maintenance charge.
Alternative to physically removing the black wire...you can pop on a $7 battery terminal disconnect switch to make it easier.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 04-03-2016, 11:57 PM   #19
I'm too lazy to pull my batteries. I bought a cheap 2 stroke $89 generator from Harbor Freight and use an extension cord with 2 male plugs on it and plug it into an external socket (yes, I know it can be dangerous). I leave the generator under the camper and come out once a month, start it, do errands, and come back 6-8 hours later to disconnect the battery. This also forces me to check the camper for any leaks that may have occurred during the winter and check for any intrusion by mice or homeless folk-don't laugh but homeless people squatting in campers in storage is becoming a growing problem.
Your way is probably best.
Skyliner is offline   Reply With Quote
Old 04-04-2016, 08:38 AM   #20
2014 Sunseeker 2650S
+1 On BatteryMinder 2012 for multiple batteries.
Note that Amazon has it a few bucks cheaper. And it you're Amazon Prime you get free 2 day S&H. And with the new Amazon Store Card, you get 5% back. We're somewhat out in the woods and it's cheaper for us to let UPS do most the driving.
Joseph Carozzoni is offline   Reply With Quote
battery
