Old 04-04-2016, 08:48 AM   #21
B and B's Avatar
Hello,
I pull my battery and do a full charge in the fall, once during the winter and again prior to reinstalling in the 5er. Store the battery above freezing in garage or basement and never charge a frozen battery, might expode.
SC-600A - Schumacher Electric
I use one of these, work well and selectable charge rate.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-04-2016, 09:38 AM   #22
Originally Posted by B and B View Post
Hello,
If the battery is charged, it won't freeze. (If it did, those us with cars up here in the north would really be in trouble!! My Silverado's outside all winter and I only drive it every couple of weeks.)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-10-2016, 04:01 PM   #23
Hello all. I have another newby question. Please treat me like I'm as dumb as a post because I really am when it comes to this stuff. We are in the 2nd year of RV'ing. My trailer came with a 12V battery, but we replaced them with two US2200 6V Deep Cycles. I have removed them from my trailer for the winter and they are in my basement. I have an old trickle charger that outputs 6V 10 amp, 12V 2 amp, or 12V 10 amp. The trickle charger displays the charging status using an old VU meter style display.
I am charging each battery separately. After charging for many hours the status does not show fully charged.
Does this mean I am underestimating the amount of time required for charging? Or am I using an incorrect output (6V 10 amp)?
Thanks in advance of your help.
Bill
2015 Palomino Sabre 33CKTS
2011 Ford F-250 6.7L Powerstroke
Newby RV'er
Nanuuk is offline   Reply With Quote
Old 04-10-2016, 04:51 PM   #24
rsdata's Avatar
How are you determining the status? A cheap $5-8$ digital voltmeter will give you the best status results... available at most hardware and auto parts stores
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-10-2016, 04:57 PM   #25
Nice pic! You'd scare someone at a campground! Thanks for your response. I am just using the trickle charger VU meter as a guide. It has four colour bands graduated by a number range of 12 (charging) to 0 (fully charged). As I said, a very old trickle charger. I wouldn't know how to use a digital voltmeter, but I'm sure my friend Mr. Google could show me. Thanks for the suggestion!
Newby RV'er
Old 04-10-2016, 05:34 PM   #26
Disconnect the charger and let the batteries rest for 24 hours then take a voltage measurement.
State of Charge for 6 v batteries.
100% - 6.37v
90% - 6.31v
80% - 6.25v
70% - 6.19v
60% - 6.12v
50% - 6.05v
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-10-2016, 07:36 PM   #27
camaraderie's Avatar
Bill
Hi Bill... I guess the first thing to do is to really test the battery to see if it is "Full".
For this you first need to disconnect for at least 24 hours. Then you have a choice to check with EITHER a voltmeter or a "turkey baster" hydrometer. I suggest you get a hydrometer as it is more accurate AND can let you identify problems in each cell (3 per battery).
Draw enough fluid out of a cell to float the float...the green and red are good indicators of condition...but the numbers are more important since they should be the same in EVERY cell.
In the "dumb as a post" category...wear goggles, have paper towels, and neutralize any spills with baking soda...this is a sulfuric acid solution. Wear old cloths too...ask me how I know!
A reading of 1.277 is perfect. Anything below 1.217 is significant loss of capacity (30%). Anything below 1.172 should be replaced. (50%loss).
To be accurate you need to ADD or SUBTRACT .004 for every TEN degress of temperature above and below 80 degrees.
Of course it is easier and quicker to just check overall voltage with a voltmeter using Boondockings chart above...but hydrometers are better if you are not disconnecting the battery from the coach and for tracing down issues. Sometimes a single cell that reads a bit different than the others simply indicates that an Equalizing charge needs to be applied. Sometimes it is a near dead cell that makes replacement necessary before you have 2 dead batteries!
In your situation, you don't know if the charger is working properly... OR if it is working and the meter isn't... OR if the batteries are sucking wind.
At 10 amps and 6Volts...you should be showing nearly full after a couple of days on the charger if the battery were totally discharged to begin with...BUT...some chargers won't jump start an almost totally dead battery
so a BIG conventional charger must be used.
If you hook up your battery to the charger and take a voltage reading at the posts WHILE charging...you should see a reading on a voltmeter of between 6.6Volts and 7.4 volts...anything outside of this range indicates a problem with the charger or a bad cell in the battery.
Hope this helps.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 04-10-2016, 07:41 PM   #28
rsdata's Avatar
Nanuuk...
a digital meter generally measures 3 functions but sometime more, these would be AC volts, DC volts and resistance in OHMS...
you pick the right scale, like DC volts and turn dial to a scale that is larger than what you plan to measure... to measure a 12 V battery use the 20 volt scale AS SHOWN in the picture below
to measure a battery, put the red wire lead on positive and the black wire lead on negative and the readout should say something like 12.6...
If you happen to get the red and black wires mixed up the only thing that will happen is that the reading will read with a minus sign, indicating the probes are switched
if you measure a voltage higher then the scale you are on the meter will say something like OL (overload) which means you need to turn to the next higher scale
very difficult to mess up especially if only using for DC readings, and very valuable to carry around with you in the camper for all sorts of electrical things
the pictures below are of a $9 meter from amazon I just happened to pick out
2014 Shamrock 183
Old 04-10-2016, 07:43 PM   #29
rsdata's Avatar
pictures did not post on previous reply
ID:	104527   Click image for larger version
2014 Shamrock 183
battery
