Old 04-24-2016, 06:54 PM   #1
Battery charging
I was told by an employee at camping world that if I connect my generator directly to my 6 volt batteries rather than go through the convertor, that the batteries would charge faster. Is that correct and is there any disadvantage in doing it? Thank you.
dernst is offline   Reply With Quote
Old 04-24-2016, 07:12 PM   #2
Jerry01's Avatar
How are you going to connect it? Plug in a battery charger to the generator and then charge the batteries or use the DC out on the generator? What brand is your converter? We have a progressive dynamics converter and only charge the batteries through that and it works very well. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 04-24-2016, 07:21 PM   #3
Clearly the employee was not an electrician!!!! I wouldn't trust one of their guys for much.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-24-2016, 07:30 PM   #4
Battery charging
I have a wfco converter 55 ah and a 2000 watt yahama generator. I was going to connect the dc directly to the battery.
Old 04-24-2016, 08:06 PM   #5
Your 2000 watt generator will supply at most 6.5 amps through the dc connection.
Better off to plug the shore power line into the generator and let the 55 amp converter do its thing or use an external (20-40 amp) charger.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-24-2016, 08:15 PM   #6
Flybob's Avatar
You will be much better off if you connect the RV to the 110V outlet on the generator and let the converter charge the battery. The 12V output from the generator not as efficient at charging as the converter.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-24-2016, 08:18 PM   #7
Brother Les's Avatar
If you charge up your battery through your converter, the converter will reduce (lower) the amount of charge input to a trickle charge the higher level the of charge that is in the battery.
If you charge your battery directly from the generator, you will get a higher and 'deeper' charge into your battery and there is no 'drop off' off charging as there is with the converter.
the tech is correct.
the disadvantage is that you can 'boil' your battery if you are not careful by charging it too long.
Use the converter.
Brother Les
Old 05-02-2016, 03:40 PM   #8
Too Tall's Avatar
I did a test today, coincidentally, to see which would charge faster, the WFCO or a Schumacher 12 amp charger. I left my two 6 volt batteries off charge for a couple of days so I'd have something to compare.
The Schumacher charged at about 8.5 amps initially and the WFCO was at about 6.5 amps. Within a few minutes the WFCO was down to 1/3 of an amp @ 13.2 volts. After connecting the old Schumacher, the charge was 2.5 amps @ 14.5 volts. This all occurred in about 15 mins as my batteries were no discharged much. However, in my experiment, the 12 amp Schumacher will charge faster than the WFCO. If the batteries were down enough to take over 12 amps, the WFCO would probably do a better job till I could put the Schmacher on to top them off.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
battery, charging
