Old 02-13-2015, 07:35 AM   #1
Toddles's Avatar
Battery charging
Hello
We just purchased a Coachman Prism Class C motorhome. The unit has a power cut-off switch that supposedly cuts off all power from the coach batteries to the coach. The question I have is if I plug the motorhome into a 110V outlet, will the coach batteries be charging if the cut-off switch is turned off?
Thanks!
Toddles is offline   Reply With Quote
Old 02-13-2015, 07:39 AM   #2
Witch Doctor's Avatar
Originally Posted by Toddles View Post
Hello
Thanks!
NO, you need your disconnect on to use your on board charger....
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-13-2015, 07:45 AM   #3
Toddles's Avatar
That's what I thought, Thanks! Do you feel it makes sense to leave the MH plugged in during winter storage?
Old 02-13-2015, 07:49 AM   #4
I keep mine plugged in 24/7 at my house, just keep an eye on the water in the batteries. My charger stays at 13.2 . I have been doing it for years no problems, the batteries are to hard for me to take out and put on a tender. Your converter should drop to 13.2 with not reading any loads. It also allows me to run a 1500 watt heater to keep the condensation out. Inside my 5er is dry as a bone.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-13-2015, 07:54 AM   #5
Toddles's Avatar
Thank you so much! This appears to be a great place for help! I've owned several travel trailers in the past but this is my first MH, so there are a few areas that I'm not familiar with.
Take care!!!
Old 02-13-2015, 09:36 AM   #6
ramair's Avatar
Welcome to the Site Toddles and you will find a lot of help with these forums. Congrats on the MH...
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
battery, charging
