Old 06-01-2014, 01:31 PM   #31
Wrapping it up. I sent an email to the manufacturers of my converter and this was their reply.
Disconnect the batteries, and turn off as much 12 volt load as possible. Monitor the voltage at the blue wire and DC negative (battery negative). The voltage at no load really should be close to 13.8VDC measured with a good quality voltmeter. Turn on 12 volt light bulbs one at the time. See how many bulbs will illuminate until the voltage drops below 12.5volts. Each incandescent lamp (bulb) will draw about 1.5 amperes. Total that amp load. If the voltage drops below 12.5 with significantly less than a total of 55 ampere load, the converter section would be considered defective and would require replacement.
Unfortunately, without a DC ammeter capable of reading 55-60 DC amperes to use in conjunction with the voltmeter, you cannot know with absolute certainty the converter is defective. However the test above works very well most of the time.
When I did this my reading were very erratic. In the 22 then 9 but mostly around 9. So I determined the converter was bad and decided to call Randy at Bestconverter and get me a Progressive Dynamic 4600 series. It came yesterday and I had it installed with a couple hours of it arriving at my doorstep. I may do one more post in a week or so saying how it has performed for me. The install was not bad at all. I am looking forward to having my batteries charge quicker and not worry about overcharging.
dlongmore is offline   Reply With Quote
Old 06-02-2014, 07:50 AM   #32
Herk7769's Avatar
That test procedure is now added to my "bag of tricks" -
Thanks for following it up.
Herk
HAM CALLSIGN - KC3FFW
Old 06-02-2014, 12:30 PM   #33
Witch Doctor's Avatar
Herk
Herk how do you add stuff like this? do you print and scan it in your computer or can you save it somehow in the forum somewhere? Thanks Glenn
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-02-2014, 12:44 PM   #34
Herk7769's Avatar
I cut and pasted the procedure from the post to Word; then edited it into something I can follow as "steps"; then save to the Herkbrary in the ELECTRICAL\WFCO CONVERTER folder as a PDF.
Old 06-03-2014, 03:17 AM   #35
Got it thanks that's a great Idea..... By the way you would love it here at SEA MIST in Virginia Beach at the Oceano NAS. Jet's just fly over us all day long doing all kindas of formations.......Sorry for the high jack....
Coachmen M/H
Concord
2018 / 300 DSC
battery, charging, converter
