Old 02-24-2016, 11:47 AM   #11
Senior member
battery charging
had that problem with my 335 only had it few months. Lucky I was camping 2 miles from my tech man. Frig and battery only working shore power and inverter keep tripping. Found that cables on battery were not secure, needed to be cleaned and reconnected same. Year later and no recurrence of that issue
efgsr47 is offline   Reply With Quote
Old 02-25-2016, 12:49 AM   #12
Originally Posted by ScottBrownstein View Post
Not to be a stickler here, but if his frig runs off an inverter, it isn't a propane/120 VAC unit, it is a residential model. As such, it has never,ever heard of 12 volts! i suppose you could power an LP/AC reefer off of an inverter but that really would make no sense.
Our 2011 Georgetown 327DS has a Dometic propane/AC fridge that we run off of an inverter. I purchased the inverter and had the dealer install it before the rig went out on its first trip because I didn't want to drive with the propane on and couldn't see running the 5500W generator for a 300W intermittent load for the fridge. When we're driving, the 175A alternator provides more than enough power to run the inverter, charge the batteries, and still meet the chassis electrical needs. The inverter has an internal transfer switch and was wired into the electrical system so that it automatically shuts off whenever shore power is available or the generator is running.
I also installed a switch in the propane solenoid power line from the propane detector. This lets me shut off the propane at the tank from inside the rv when we're driving.
Phil
pmsherman is offline   Reply With Quote
Old 02-25-2016, 08:36 AM   #13
Originally Posted by pmsherman View Post
Our 2011 Georgetown 327DS has a Dometic propane/AC fridge that we run off of an inverter. I purchased the inverter and had the dealer install it before the rig went out on its first trip because I didn't want to drive with the propane on and couldn't see running the 5500W generator for a 300W intermittent load for the fridge...
Phil
Makes sense, that's a new one for me, never heard of anyone doing that. I guess as long as the alternator is supplying the power it's no problem. When running from batteries, the AC section of a propane/AC reefer is really inefficient as it is merely a hot wire resistance heater. Taking 12 volts to make 110 to make heat is not a very optimal process.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-28-2016, 09:18 PM   #14
Phil
Phil
The only issue I see is whether or not the wiring from the alternator to the inverter is heavy enough to support the 25 amp plus load you are putting on the alternator. Depending on the distance, you want at least 6 gauge wires making that run to avoid the voltage drop. If you have much of a voltage drop, the batteries are going to carry the load instead of the alternator (and the batteries will not be charging).
Fred W
Old 02-29-2016, 08:07 AM   #15
Originally Posted by pgandw View Post
Phil
Fred W
On a class A chassis the alternator feed is designed to support a residential refrigerator and inverter option. That means that the feed will handle an inverter load with no problems and still manage to top off the house battery bank.
2015 335DS
Old 03-02-2016, 01:21 AM   #16
Phil
Fred W
Actually, it's the wiring from the alternator to the battery, not the inverter. I believe the dealer used 2/0 wire from the battery to the inverter, around 6'. The inverter draws 25-27A at 12V when the heater in the fridge is running. Next time I'm running it that way, I'll check the house battery voltage while the fridge is drawing power for its heater. I have a two decimal DVM monitoring the battery so it should be easy to see the voltage drop.
Newer units with residential fridges would have a charge wire heavy enough to carry the current needed for the inverter but since mine didn't have that type of fridge, I might have a smaller charge wire. 20' of #10 wire has a resistance of 0.02 ohm. At 25A, this would cause a 0.5V drop in the voltage delivered to the battery. #8 wire would be 0.013 ohms, with a corresponding voltage drop of 0.325V.
Phil
Old 03-02-2016, 09:08 AM   #17
[QUOTE=...Newer units with residential fridges would have a charge wire heavy enough to carry the current needed for the inverter but since mine didn't have that type of fridge, I might have a smaller charge wire. 20' of #10 wire has a resistance of 0.02 ohm. At 25A, this would cause a 0.5V drop in the voltage delivered to the battery. #8 wire would be 0.013 ohms, with a corresponding voltage drop of 0.325V.
Phil[/QUOTE]
I doubt that. The wires from the alternator are designed to charge the battery bank, regardless of what is drawing it down. My bet is #6 since FR seems to use it in the battery section, with the exception of inter battery and battery to BCC wiring, which is #4. In fact, I have a 25 foot run of #6 from my 70 AMP converter to the battery bank. Sure it is rated for 70 amps, but has a big voltage drop at that length with 70 amps...but then it hardly ever puts out 70 amps...but the #6 has a lot to do with that!
Imagine what it would be like to build one if you constantly had to refer to a build sheet for wiring that every coach has!
2015 335DS
Old 03-05-2016, 03:12 PM   #18
I measured the effects of the inverter drawing 26A for the fridge heater. The voltage drop is 0.20V which leads me to suspect that the charge wire is around 12' of #8. If I run the inverter at full output, 1kw, that would be around 100A and would have a voltage drop of 0.8V. With 14.1V at the alternator, that's still 13.3V at the battery which should keep it charged. Of course, running 100A through a #8 wire exceeds its rated capacity which will cause it to heat up, increasing its resistance. #8 wire, used for chassis wiring (not in a bundle), is "conservatively" rated at 73A. ( American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength ).
Phil
battery, charging
