Old 10-24-2015, 09:38 PM   #11
Blackhat6mike's Avatar
Originally Posted by harderd View Post
He said it is drawing down even when the camper is plugged in. Suggests the converter is not charging. It may just be a bad converter all around.
X2 I agree, sounds like the converter went south.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-25-2015, 01:51 AM   #12
mud yapster's Avatar
X3 if your connected to shore power the converter/charger should be keeping your battery fully charged. Check you converter/charger. Maybe you blew a low voltage fuse or worse case the converter is bad.
mud yapster is offline   Reply With Quote
Old 10-27-2015, 03:55 PM   #13
I installed a battery cut off switch at the battey neg. post. This will stop battery drain...
Gee Whiz is offline   Reply With Quote
Old 11-28-2015, 11:06 AM   #14
Along this topic ..
If I don't plan on any camping for a month or two. Does the group think/know it's ok to just let the battery die and then I recharge it fully prior to departure?
This is an alternative to purchasing a battery tender and leaving it plugged in for two or three months with no planned camping
Greg
Greg
2014 24 IKSS Roo
2012 F150 Quad cab eco boost w/tow package
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 11-28-2015, 11:09 AM   #15
Originally Posted by fyrdad View Post
Along this topic ..
Greg
Greg
2014 24 IKSS Roo
Dont let it Die,just take off a cable,any Good Batt. should last 2-*3 months! Youroo!! PS a Dead Batt will freeze & Bust!
Old 11-28-2015, 11:28 AM   #16
The battery is already dead(it's how sister in law left it to me) I removed the battery and have it in my garage, was planning on fully charging it and then leaving it alone
Greg
2014 24 IKSS Roo
Curry's
2014 ROO 24 IKSS
Old 11-28-2015, 11:32 AM   #17
northstar1960's Avatar
Along this topic ..
Greg
Greg
2014 24 IKSS Roo
unhooked your battery should not lose full charge if it's a good battery . just charge when you get ready to leave
northstar1960 is offline   Reply With Quote
Old 11-28-2015, 11:47 AM   #18
If I read this correctly, all of this happened with the TT plugged in to shore power. If that is correct, the battery should never go dead in this situation unless there were loads turned on that in total, exceeded the output capacity of the converter. On my rig that is 70 AMPS of DC.
Now, when you are connected to shore power, the battery gauge on the panel will always read 100% since it sees the output of the converter which is at least 13.25 volts and a full battery is less than that. As such, if you are plugged in to 110V and the battery gauge reads less than 100% either your converter is dead, it has a blown fuse, it is turned off at the breaker panel or something is wired incorrectly.
When you take the battery out and are still plugged in to shore power, do the lights work? If they do, the converter is at least putting out 12 volts or something near that.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 11-28-2015, 04:55 PM   #19
If you let a battery go completely dead, odds are you won't be able to charge it up again. Dead is DEAD! If it does take a charge, it probably won't hold it. Install a new battery AND a disconnect switch and do it right. IMHO, I wouldn't leave home with the old battery onboard.
Old 11-28-2015, 06:41 PM   #20
Plugged into shore power 24-7 for a few months can ruin a battery . it will be charge all the time by the converter and no drain will cause the battery to sulfate and shorten it's life span . While i stay plugged in all the time i use the battery disconnect . then ill run the batteries down once a month about 40% and charge them up . this keeps them in good shape
battery, charging
