Battery Charging Question"s
I have a Sunseeker Class C 2005. I have been having problems with my conveyance center turning off when I am hooked up to 110 AC hook ups. The 12V house batteries weren’t receiving any charge when hooked up to 110AC, running generator, or running engine. I took it to the dealer and they said they found a loose ground wire. The also tested the batteries under a load and they checked out ok. This temporarily fixed the problem.
Now it appears that the batteries are not getting charged when I am hooked up to 110. My batteries discharged from 14,15v to 12.3V in a 12-hour period without anything being in use other than the refrigerator. At this point the convenience center was still working.
Question 1: If I turn off the battery on/off switch inside of Motorhome while connected to 110V the convienance center shuts off. Does the battery switch always have to be in the “on “ position when connected to 110 in order for the Convenience Center to work?
Question 2: I have a WFCO Ultra Distribution Panel Power Converter. I am trying to understand the function of the micro-controller. If the batteries drop to 13.2VDC the power converter should automatically change to bulk charge mode (14.4VDC). If batteries drop to 13.2VDC it means batteries are at 50%.. Should batteries always show a charge of 13,2VDC or Higher when hooked up to 110VAC?
Question 3: On Thursday I turned off the 110VAC and turned it back on about 10 minutes later. The house batteries showed a charge of 14.15V then approx 10 minutes later the batteries showed 12.97V while I was still connected to 110VAC. It appears the Distribution Panel wasn’t charging. The only power I had on was the Refrigerator. Is the Distribution Panel working correctly?
Question 4: Is it ok to use a Deep Cycle Battery charger to charge House Batteys when I am connected to 110VAV hookup?
Any Info would be greatly appreciated.
Co Salmon
