Old 09-12-2012, 10:08 AM   #1
JEM
Battery Compartment
I have white power on metal parts in battery compartments. See attached photos. I am have trouble sliding the battery tray out to check/fill batteries.
I has problem in past and removed batteries, cleaned tray, painted, and put the battery pads in bottom of tray.
Can this be prevented ?
Jim McAfee
2011 Birkshier390bh
JEM is offline   Reply With Quote
Old 09-12-2012, 11:38 AM   #2
Berkshire 390QS
NO3putt's Avatar
Having some of the same problems in battery compartment. Some expert advice would be helpful. thanks
Old 09-12-2012, 12:31 PM   #3
Triguy's Avatar
Not an expert, but here are my thoughts. It appears that the batteries boiled over indicating a charger or battery problem.
Do you know what your converter's float voltage is?
I would also check the batteries with a hydrometer to confirm there are no bad cells.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-12-2012, 12:43 PM   #4
Dallas Texas
TexasBBQ's Avatar
Once the corrosion starts you have to thoroughly clean and neutralize it or else it just keeps growing. Use a mixture of baking soda and water to neutralize it. Wear appropriate safety gear because it will foam up. I would remove the trays for the cleaning if possible. If a lot of the paint is gone it may be best to remove all the old paint and replace with acrylic or epoxy paint.
Might want to get the red and green doughnuts for the battery post and spray the red corrosion goop on them. You can find it WallyWorld or the auto store. Be sure your batteries are well ventilated to the outside
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
battery
