Old 05-20-2015, 08:21 PM   #1
Thumbs down Battery Connection Spark
Just got a new 2516 pup, and I am very happy with my camper. My question is: When I reinstall my battery after charging it, I get spark while putting the positive cable wire on the positive post. I've been taught "the negative is the first one on and the first one off," and I live by that rule. Could something in the trailer be drawing a lot of juice from the battery? If so, I how do I turn the whatever off so my battery won't spark? The main switch to the lights is off and the stove is in its travel position on the floor.
Thank you in advance.
J. Clark, Alamo, Texas and Big Bear Lake, Ca.
eteacher44 is offline   Reply With Quote
Old 05-20-2015, 08:25 PM   #2
Flybob's Avatar
You can add a battery disconnect switch and make the final connection that way, but there is always something on when the battery is connected, At a min the CO/propane detector is on, If you have a remote control radio it us always drawing some power.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-20-2015, 08:29 PM   #3
Arn
Arn
Hmm, my thinking is positive first on & last off. That way if the loose cable touches something it's your ground wire, not a live wire, therefore no spark.
Arn
Arn is offline   Reply With Quote
Old 05-20-2015, 08:31 PM   #4
Connect the positive first and disconnect the negative first, much less chance of creating a short with the wrench. You may still get a small spark when you connect the neg.
15 Flagstaff 26RLWS
08 Silverado 1500 Crew
dlc49 is offline   Reply With Quote
Old 05-20-2015, 09:03 PM   #5
Timex's Avatar
Just put it on fast!
No spark.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-20-2015, 09:13 PM   #6
f5moab's Avatar
I agree, negative is first off, last on. How do I remember that? Installed negative first and then was cranking on the positive cable bolt on a car many years ago, and the wrench connected with a cross brace. Then I banged my head on the bottom of the hood when I jumped.
I do not have a disconnect switch, but I remove the 30A inline fuses before disconnecting and don't install until connected and never had a spark. (If one battery, there will only be one inline fuse.)
f5moab is offline   Reply With Quote
Old 05-20-2015, 10:02 PM   #7
I seem to be in a mood today! Just be aware I actually censored my first thought.. lol
A battery side disconnect is never a bad idea.
rana is offline   Reply With Quote
Old 05-21-2015, 02:15 AM   #8
Crockett's Avatar
Smart charger capacitors
These caps are usually the source of the large spark on battery hookup. You can verify the spark source as caps if you spark it a few times in succession. The spark intensity will dimish fairly rapidly.
Crockett is offline   Reply With Quote
Old 05-21-2015, 05:31 AM   #9
I don't get a large spark when connection but I do get a spark. I figure that between the circuit boards for the fridge and water heater, LP detector, the radio, the new Lippert sides that have the brakes energized when in position, it adds up.
Filthy Beast is offline   Reply With Quote
Old 05-21-2015, 07:36 AM   #10
silver's Avatar
Your electronic circuits hate to have power attached with no ground or a floating ground. It is the best way to blow them out. That would say positive on last and off first.
silver is offline   Reply With Quote
battery
