Old 10-23-2018, 11:55 AM   #1
Battery Connections
Hello,
E-Pro 14FK
The dealer connected 2 -12v batteries in parallel correctly....
Camper to Positive 1 - jumped to positive 2.
Camper to Negative 2 - jumped to negative 1.
The (I think) inverter and solar are connected to battery 1 negative and battery 2 positive.
Should the solar be connected to battery 1 positive and battery 2 negative? Or does it matter and the dealer setup is okay?
I have seen videos with solar on battery 1 positive and battery 2 negative, but, the dealer did not do it like that.
Which is correct?
Thanks for any input.
JS Stanley is offline   Reply With Quote
Old 10-23-2018, 01:05 PM   #2
I think the best way for charging is to put pos to pos on bat one and neg to neg bat two in parallel. However the way your dealer did it will work but not optimum.
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 10-23-2018, 01:21 PM   #3
Trailer Park Supervisor
NJKris's Avatar
Following this. Good question.
NJKris is offline   Reply With Quote
Old 10-23-2018, 01:47 PM   #4
The dealer has connected it properly and the optimum way.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 10-23-2018, 02:14 PM   #5
why do you say that?
AZ Pete is offline   Reply With Quote
Old 10-23-2018, 02:18 PM   #6
It's called balanced charging
https://www.impactbattery.com/blog/t...s-in-parallel/
Old 10-23-2018, 04:04 PM   #7
The OP explained how it is hooked up and that is hooked up in a balanced charging way.
2007 Surveyor SV230
Old 10-23-2018, 11:15 PM   #8
with only two batteries, it seems that he has it set up as "balanced charging.
Old 10-24-2018, 08:10 AM   #9
Fulltime family RVer
In my tiny bit of understanding, as long as it’s hooked up to one battery’s positive and the other battery’s negative, it doesn’t really matter which way they are (bat1+/bat2- or bat1-/bat2+).
Your dealer’s connections sound fine to me.
Old 10-24-2018, 08:37 AM   #10
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
X3, connected correctly. Most will connect positive to batt #1 first, but there is nothing wrong with the way as described. Without pictures, they may have done it like that to keep the wiring a bit more tidy. May have done so there were not too many connections stacked on the same terminals.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
A Loving wife
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is online now   Reply With Quote
battery
