Old 03-13-2015, 09:28 AM   #1
Battery control center issues
I have a 2013 forester 3011ds the battery control center has just started clicking. I looked in side and there is a big relay with battery cables chassis and coach battery that keeps clicking. I have had no issues but not sure what it is doing it clicks about every 5 min. I do have the motor home connected to shore power all the time. I have a 30 amp camper outlet at the house and keep it connected. I can't find any information on this battery control center.
Any help would be great.
Zoe-Woody is offline   Reply With Quote
Old 03-13-2015, 09:37 AM   #2
KyDan's Avatar
A shot in the dark...... have you checked water in all your batteries?
Are any of them warm to the touch??
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-13-2015, 12:18 PM   #3
Thanks for the information. I did check the batteries and they seemed fine. However, did find a lead loose on the one of the neg terminals and also a lead loose on a battery switch. When I tightened them the clicking stopped I am going to look again in a bit.
Thanks for your help it did point me to the batteries may be the problem
Old 03-13-2015, 01:26 PM   #4
bubbles's Avatar
Could it be the relay switching between charging your coach battery and chassis battery? Coach battery would have priority. Just a thought.
Old 03-13-2015, 04:18 PM   #5
Thanks for the information my loose wire didn't fix it
I checked the batteries and all three of them are fine not hot and have liquid. I think you are right it is the relay switching between coach and chassie but all batteries are fine. I have checked the voltage at the switch and it shows the voltages of the batteries. The camper starts fine and is charging fine. I took a relay out and it stopped clicking. Not sure if you can add photos to this . I have looked ont eh web and can't find anything on this battery control center
Old 03-14-2015, 12:18 PM   #6
2016 Avenger 26BH
Is it a relay? ooorrrrr is it a circuit breaker that is overloading and resetting? Just asking. Sometimes they look very similar but have their own functions.
Cleon is offline   Reply With Quote
Old 03-14-2015, 12:47 PM   #7
bubbles's Avatar
If it is the switching between batteries this is a normal occurrence. Same thing would happen while driving with the chassis battery charging first before switching over to your coach battery. Keeps all batteries fully charged. I'm done.
Old 03-14-2015, 07:01 PM   #8
It is definitely switching to charge all batteries. However, it does it about every 5 min when not running. The batteries are no where near flat and are holding a charge very well I had them checked. There are two relays one is a small black relay with nine terminals (I removed this to make it stop). The other is a round relay which will connect the two sets of batteries together. I am thinking there is an issue with what ever monitors the chassis battery and switches. I have monitored the batteries and the veh battery has 14.3 when running but then the battery drops to 12.85 volts when the veh is turned off and the switching starts. Start the veh again and the clicking will stops. I don't think 12.85 is low and would or should bring on the relay to,charge the batteries. Having said this I am not expert and if this is normal for a motor home. I have had the relay unplugged for over 24 hrs and the clicking has stopped and the veh batteries have stayed changed and start the veh fine so no major voltage leak. Thanks for all your help and any other ideas would be great.
Old 04-27-2015, 05:47 PM   #9
Average Joe
MrJoe's Avatar
My Sunseeker is doing the same thing. The relay/solenoid in the stairwell will switch every few seconds. It will do this for 10 minutes or so. I never noticed this before. This is happening when plugged in to shore power.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 05-19-2015, 11:02 AM   #10
Average Joe
MrJoe's Avatar
Sunseeker BCC going nutz
Has anyone else experienced this issue? Mine is a Wurth BCC and the switching is almost constant while plugged in. I did a search on Wurth and couldn't find support or parts... ??
Joe and Karen
battery
