Old 06-06-2016, 07:37 PM   #11
We plugged the camper in to shore power yesterday when we got home from camping, and when he went out today about 3pm there was no power to anything. So he unplugged it from shore and the battery was dead so he has had it on battery charger since. Its not at a full charge but he did check it and it was reading 12.
Glamping4fun is offline   Reply With Quote
Old 06-06-2016, 07:41 PM   #12
We do not have a battery cut off switch. He said its reading 11V when plugged in to shore.
Old 06-06-2016, 07:43 PM   #13
Flybob's Avatar
OK. Either the converter is dead, the fuses that looked good are really bad or you have a battery cut off switch, 11V on a 12V battery is zero charge
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-06-2016, 07:59 PM   #14
Thank you, we are leaning towards the converter being bad. Do we need a battery cut off switch in the future? He used the troubleshooting suggestions in the book also and hooked the voltmeter to the positive probe on the +vcc output terminal lug and the negative test probe on the NEG- out put terminal lug and it read 0. Any suggestions on where to get a converter? Amazon?
Old 06-06-2016, 08:06 PM   #15
Flybob's Avatar
If you are going to go to the trouble of replacing it, Most people recommend Progressive Dynamics. They have an replacement and it is a much better charger.
TST Tire Monitors
2 100W solar panels
Old 06-06-2016, 08:17 PM   #16
Thank you for your help!. It's greatly appreciated.
Old 06-06-2016, 08:23 PM   #17
It was plugged into shore power at the time it was tested, right?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-06-2016, 09:26 PM   #18
I'd be very surprised if your unit did not have a battery cut-off switch. The only units I know of that are made without battery cut-off switches standard are pop-ups - and these have batteries out on the trailer tongue.
That said, your battery cut-off switch is on for everything to be working while the battery has any charge left in it. There's only a few possibilities:
- converter circuit breaker is not "on". Usually, the converter has its own circuit breaker on the AC panel. Physically turning a circuit breaker off, then on is the proper way to reset a circuit breaker.
- converter is not providing any DC power, leaving the battery to provide all the DC power. But you should not read 0 volts on the converter battery terminals if the battery is powering the camper DC. That reading really bothers me, and does not make sense unless the battery was disconnected when you took the reading.
- somewhere, somehow, the connections between the battery and converter are not there. A blown fuse or a disconnected wire would be suspects.
If you have a WFCO converter, Progressive Dynamics makes well-repected drop-in replacements for the most common WFCO models. But the converter is the most expensive component to replace, so I would make real sure it is indeed the converter that is not working.
Also, I would consider your battery is pretty much toast, having been discharged as far as it has - probably more than once. Many converters will not charge a dead battery, and may/may not pop the big fuses in trying to do so (mine did).
Last but not least, you need to disconnect the battery - either manually or with a switch - when in storage without being plugged in.
Fred W
2014 Rockwood A122 A-frame
two Interstate 6V 232AH golf cart batteries, disconnect switch installed
WFCO converter that will not go into trickle charge mode
battery, converter
