Battery.......Corrosion and Questions
Trailer stays hooked up in driveway to 50 amp shore power RV receptacle.
I just went out to check on the batteries. 4 six volts........double 12v setup. Have several questions, need advice.
1) Battery terminals are starting to show a white powder, corrosion. Batteries are about a year old. Trailer is 8 months old. If nothing else, I plan on cleaning them with a wire brush and spraying some kind of auto battery corrosion spray on them. To do that requires disconnecting them, they are WEDGED in there! I'll do that tomorrow.
Thoughts?
2) There is a tiny bit of water/wetness on the top of a couple of the batteries. The door was ajar (I guess I forgot to close it when unhooking 2 weeks ago when I brought it home from dealer getting new roof and a/c unit. It COULD be rainwater? It could be leakage. I will of course check the water level when I get them unhooked to clean the terminals.
3) Batteries are Provolt brand. Never heard of them. After all the issues I've had with slides, I do NOT want batteries to be a problem. I see a recent thread about a Cardinal 5'er that the OP had similar slide issues to what ours started out as, and found a bad ground cable, and corrosion, and when fixed that fixed his problem. Should I replace? Would you? Or just clean up and refill?
Will review any answers. Heading out for a while in a bit. Whatever I do will be done tomorrow or next week
Thanks.
FROG AR-0019-242
