Old 02-06-2015, 08:15 AM   #1
Battery Dead
We just bought our first RV. It is a Grey Wolf 25RL. We picked it up from the dealer Tuesday night. During the walk through they told us it was a brand new marine battery. They had it plugged into shore power during our walk through. They shut everything off and we hooked it up and brought it home. We set it up in the driveway, still with everything off and left it that night. The next night probably less than 24 hours later we went to start setting things up and the battery was dead. This doesnt seem right to me. We are going to be leaving tomorrow for our first trip and I wonder if we shouldnt go back to the dealership for a new battery. It seems with nothing on in the camper the battery should last longer than that!! Any advice would be appreciated!!!
harpo029 is offline   Reply With Quote
Old 02-06-2015, 08:32 AM   #2
fonzie's Avatar
Is there a battery disconnect switch? It might be off
Fonzie
Old 02-06-2015, 08:42 AM   #3
Brother Les's Avatar
These are parts of learning your unit. Did the connection at the battery come loose on the way home? Check the connections. Look things over. Do you have a volt meter to check the battery directly? Do that. If you live close to the dealer, give them a call and talk to them. The battery should be no way 'dead'. Something that you did not openly see may have been left on. Can you plug in your unit at home to shore power. I am sure that you may not have a 30 amp plug at your house, so you should have/get a 30to15 adapter. Walmart sells these. If not able to plug into the house just yet, back your truck up to the unit and with the truck running, plug it into the cord (make dang sure that you unplug it when done and not rip it out of the connector,if you are not 'on the ball' and pull away) does the lights, etc. work now? Is the 'converter' switches on for 12v, look at the panel? Should be an easy fix if you take you time and walk through things.
Brother Les
Old 02-06-2015, 08:42 AM   #4
Flybob's Avatar
Check to see if everything is shut off , Furnace, Fridge, WH. If you have a battery disconnect, make sure it is not turned off. Make sure the breakaway switch has not been activated. If you accidentally pulled the breakaway cable while unhitching you may have pulled the pin out enough to activate the brakes. Brakes do not go through the convertor fuse system. Check to make sure you did not hit the tongue jack light switch and leave the tongue jack light on. Check lights in basement/pass through to make sure they were not left on. You will always get some current draw from the propane detector, but that should take weeks to kill a battery. If you have a battery charger I suggest you use it to get a base charge in battery before charging it via the convertor in the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-06-2015, 08:56 AM   #5
As far as we know nothing came lose. I know for sure fridge and all lights were turned off. Husband hooked up a battery charger to it the next day at 10 amps for about 5 hours and we had lights last night. But after maybe 30 minutes in the camper with just some of the lights on and nothing else it was almost drained again. He plugged it back in on 2 amps for about 6 hours after we were done and the smoke detectors inside are still beeping. I think I am going to call the dealer because none of this seems right to me.
Old 02-06-2015, 09:02 AM   #6
Flybob's Avatar
Check the breakaway switch and make sure it not activated. ( push the plunger in as far as it will go). That's a lot of current draw so it has to be something big like the brakes.
TST Tire Monitors
2 100W solar panels
Old 02-06-2015, 09:05 AM   #7
I have mssg my husband to have him check the breakaway. I also have a call into the dealer. We live less than 1/2 mile away from them so if we need to we can bring it up there and have them check or replace that battery if needed. I appreciate the advice!! When we find the culprit I will let you guys know!!
Old 02-06-2015, 09:11 AM   #8
Phat Phrog Stunt Crew
elind's Avatar
Start at the battery and follow the red wire. It should go a terminal with mini breakers. On the side of the mini breakers is a mini reset button on the side of it. Press it in, done!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 02-10-2015, 02:57 PM   #9
We did end up taking it back up to the dealer and they checked it out and everything was fine. It seemed there was not a full charge on the battery when we first brought it home. We are still not sure why the smoke detector was beeping again the next night because the other power was working. He is set up at his camp ground now and on shore power and everything is working as it should. Thanks again for all the suggestions!!
Old 02-10-2015, 03:10 PM   #10
Your smoke detector should have a small 9v battery in it. If it is beeping, then the battery is dying. Replace it.
The Dealer should have replaced the battery AGAIN when you took the unit back, with a NEW fully charged one. 'If' it was 'dead' (died) because it was not fully charged, it now has a greatly reduce 'life' because of being full discharged. I would tend to not believe the excuse that the dealer gave you, it 'still' 'discharged' too quickly, even for a partially charged battery. imo. a loose connection or a fuse 'popped' and the dealer reset it and does not want you to ask any more questions.....
Brother Les
battery
