What is the voltage at the battery terminals when you are plugged into 50 amp?
If less than 13 volts you have either an open circuit breaker (right before the red wire gets to the battery, corroded wire connection somewhere from the converter to the battery, or a bad converter.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
