Old 09-29-2013, 10:40 PM   #11
Denver, CO
garbonz's Avatar
Funny. You can get a battery monitor and find out by turning the circuits off one by one.
I'm guessing your battery may not be strong. A couple weeks maybe, but not 3 days. EVERYONE needs a battery shutoff or to disconnect for anything longer than a week. And it only takes one cycle discharge to dead to kill or seriously damage a battery.
2017 Fuse 23T
Old 09-30-2013, 06:25 AM   #12
also the small solar panel you have on it will likely not have a blocking diode in it. so every night the solar panel is discharging the battery not charging it. it will discharge more than it can charge all day. i have a feeling that the solar panel is your problem. if left unplugged i would turn off the battery disconnect to prevent the propane detector from drawing on the battery. the co detector is run off a 9volt battery.
18 3500 denali duramax cc srw
silverback 31b2
skidoonut is offline   Reply With Quote
Old 09-30-2013, 07:31 AM   #13
Herk7769's Avatar
This is an excellent answer.
Additionally, if the battery is fully charged at the beginning (WILD assumption in this scenario), a fully charged OEM 12 volt battery contains about 70 amps hours of battery life when discharged at a constant 5 amps. That life varies greatly by the actual discharge rate. Less amps; longer life. More amps; shorter life.
The graph below shows a new, fully charged, off the shelf, never discharged 100 amp-hour RATED battery's expected life at various discharge rates.
NOTE: Even though "rated" at 100AH at 20 amps, the ability to deliver that charge changes as the battery voltage drops during use.
So, to sustain a 100 AH total life (capacity), the draw must be about 5 amps. 100 hours is a bit over 4 days. A 70 AH OEM battery would last 70% of 4 days (or 2.8 days) for a fully charged battery.
To estimate a 70 AH battery's curve adjust the left axis to read "percent" of the total new AH of your battery or bank.
Note that LESS than 5 amps continuous draw will give additional battery life, but not a lot more. Getting a week (without your panel) is about "normal" for a fully charged battery; WAY less putting it away with something less than full charge.
For solar panel planning, a blocking diode is critical because anytime the sun is not charging the battery, the panel will consume power from the battery. Cheaper panels (without controllers) do not have them.
Completely discharging a battery (called a complete cycle in deep discharge batteries) damages the plates every time it happens resulting in reduced capacity due to the inability to hold as much charge as when new. Battery manufacturers design the plates based on the number of cycles the battery is planned to have before it needs to be replaced.
See the second attachment (text) to see how depth of discharge effects battery cycles. (and yes Virginia, there IS a difference between manufacturers and it shows up in the battery price).
This link has a wealth of information on this topic.
Battery Life and How To Improve It
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
ID:	40442   Click image for larger version
Name:	battery Life as a function of charge discharge cycles.jpg
HAM CALLSIGN - KC3FFW
Old 09-30-2013, 09:40 AM   #14
RPAspey's Avatar
You brought up a really good point. As the solar panel has such a small output, it likely doesn't a blocking diode or even a controller. If there is a diode, it could be bad.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 10-01-2013, 01:52 PM   #15
Denver, CO
garbonz's Avatar
GET and BATTERY MONITOR, and you can actually answer your own question.
2017 Fuse 23T
Old 10-01-2013, 02:21 PM   #16
Rebel702's Avatar
Battery disconnect is in the right side propane compartment. Round silver handle.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 10-01-2013, 03:17 PM   #17
Maybe on yours, Reb; not on mine!
corcelli is offline   Reply With Quote
Old 10-02-2013, 01:01 AM   #18
Rebel702's Avatar
Just trying to help you find the disconnect. That is the location on all the Jammer's I have seen.
EQ-4, 14,000/1,400
2006 Yukon Denali
battery
