Old 04-06-2012, 10:53 AM   #1
pattersonb's Avatar
Battery Disconnect?
While storing my 5th wheel at my home during the travel season, I typically leave the unit connected to AC shore power. I've never had any problems with the battery being overcharged or "boiled dry", but am wondering if it would be prudent to use the battery disconnect switch as an additional measure to prevent those from happening. Thanks!
pattersonb is offline   Reply With Quote
Old 04-06-2012, 09:41 PM   #2
TURBS's Avatar
I leave mine plugged in 24/7 365 but I still have a battery kill .
mine does several things tho . its four position .
positions
battery 1 on 2 is off
battery 2 on 1 is off
battery 1 and 2 on
battery 1 and 2 off
that way I can kill both batteries or keep one offline for reserve or use both for longer amp hours .
Old 04-06-2012, 10:20 PM   #3
Herk7769's Avatar
My switch is red but it does the same. Normal position for me is both on.
Is one or the other batteries should go bad, I can just switch it out and not ruin a camping trip.
HAM CALLSIGN - KC3FFW
Old 04-06-2012, 10:22 PM   #4
TURBS's Avatar
I guess I never looked closely at yours Herk ! It is basically the same ! just different hmmmm is that right ? ok ok different brand same function.
I leave mine on 1 and 2 as well !
battery, battery disconnect
