Old 08-06-2014, 03:50 PM   #1
Battery Disconnect
Trying to get my head around the use of the switch and now I have to ask a somewhat simple question. When the trailer is plugged in is the battery switch supposed to be connected or not?
Thanks in advance
Tom
tsattwoo is offline   Reply With Quote
Old 08-06-2014, 04:34 PM   #2
RSchleder's Avatar
Yes, typically leave the 12v battery disconnect ON for shorter stays. This way you are assured of keeping your battery fully charged when sitting still. If you are staying in one local for an extended time, say 15+ days, it would be best to turn the disconnect switch OFF so the batteries don't lose a great deal of water due to the continuing "charging effect" of the inverter or converter.
RSchleder is offline   Reply With Quote
Old 08-06-2014, 04:36 PM   #3
It should be closed or "on" to connect your coverter to the battery to charge it.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 08-06-2014, 05:33 PM   #4
Thanks for the replies that is what I had thought.
battery, battery disconnect
