Old 10-01-2015, 02:56 PM   #1
PokerDealer's Avatar
Question Battery disconnect
I was looking at battery disconnect switches and they have Amp ratings, typically from 100 to 300. I have 2, Trojan T105's a total of 450 amps. Do I need a switch that is rated for that amount of amps?
PokerDealer is offline   Reply With Quote
Old 10-01-2015, 08:02 PM   #2
If do not have a big inverter installed that is going to draw a lot of amps then a 100A switch should do you just fine.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 10-01-2015, 08:17 PM   #3
Your not disconnecting the potential but the load. The battery potential may be several hundred amps but the trailer load without a short is seldom 100 amps. The wire size to handle 100 amps is far larger than most trailers will have between the batteries and the distribution panel. fwiw, Tim
Timtation is offline   Reply With Quote
Old 10-02-2015, 12:02 AM   #4
Thanks, it makes sence now
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
battery, battery disconnect
