Old 06-30-2016, 03:46 PM   #1
Battery Disconnect and Connecting to AC Power
Can the battery stay disconnected when hooking up to AC power?
navman28 is offline   Reply With Quote
Old 06-30-2016, 03:50 PM   #2
Pickin' & Campin'
It can but some converters do not handle 'no load' situations (battery disconnected) very well. (high voltage output)
I recommend the battery(ies) remain connected while on shore power.
Just remember to check the electrolyte as often as needed.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-30-2016, 04:23 PM   #3
Thanks. Just trying to figure out if last week when I plugged in to ac power and noticed smoke from the converter area was caused by connecting ac power with the battery disconnected or by the 220V from the ac power source. My vote is on the 220v as the cause.
Old 06-30-2016, 05:35 PM   #4
Pickin' & Campin'
220v on a 30 amp 110 circuit will let the smoke out for sure!
Old 06-30-2016, 05:36 PM   #5
Pickin' & Campin'
Check other things too. Most likely several things fried.
Old 06-30-2016, 05:44 PM   #6
Mr. Dan's Avatar
We're hoping you're one of many people who are confused by RV electrical outlets and that you didn't actually hook up to a 220v power source. Can you post a picture of the outlet you used?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-30-2016, 05:45 PM   #7
Exlimey's Avatar
The battery acts as a capacitor/filter for the converter DC output. Without it, you'll get excessive ripple voltage on the 12 DC output. I wouldn't operate on shore power without the battery connected. Also, I'm betting that some of the electronics in the camper don't like the ripple.
Neil and Kimberli
2016 Silverado Z71 double cab
2016 Flagstaff 29KSWS Super Lite
Nights camped 2016 - 27
Nights camped 2017 - 81
Exlimey is offline   Reply With Quote
battery, battery disconnect, power
