Old 04-05-2015, 04:51 PM   #1
The Mustard Seed's Avatar
Battery Disconnect Question
Hello fellow campers. I have a question regarding the positioning of the battery disconnect switch. Mine is a red switch that has two positions: on and off. Can someone tell me when the switch should be in the on position and when it should be in the off position. We have not yet taken the mustard seed out camping. We have been busy cleaning, organizing, general maintenance, and repairs. So, before we hit the road, I'd like to know the proper use of the battery disconnect switch. All the documentation and manuals are very generic and not so informational. Thanks for your help.
Hunter & SweetC
2 Wild Westies - Brody, Morgan
2012 Ford F-250 Super Duty 6.2 Liter
2018 297 RSK Primetime Crusader
The Mustard Seed is offline   Reply With Quote
Old 04-05-2015, 05:00 PM   #2
Blackhat6mike's Avatar
Battery Disconnect Switch
The switch is used to disconnect the batteries from the unit when not in use so as not to have the parasitic devices run the bats down. When you need 12vdc, switch it on.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-05-2015, 05:18 PM   #3
Thanks for the quick reply. Maybe I'm hard headed, but if you can help a bit more I'd appreciate it. What position should the switch be in when: 1. traveling to a campsite or cross country 2. at the RV park and hooked up to electric 3. sitting in my driveway hooked up to electric waiting for next trip 4. dry camping. Thanks for all the help.
Hunter & SweetC
Old 04-05-2015, 05:47 PM   #4
spierce617's Avatar
All of these I would have the switch in the on position. When I store the camper and do not have shore power attached to the camper that is when I turn the battery switch to off.
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-05-2015, 06:04 PM   #5
bubbles's Avatar
Another case of ambiguous labeling. Is ON/OFF referencing the battery or the disconnect. Ridiculous without accompanying labels.
Old 04-05-2015, 07:42 PM   #6
The switch needs to be on if you are using the onboard converter/charger while connected to shore power or your batts will not be connected.
Old 04-06-2015, 08:31 PM   #7
Wouldn't it be great if the switch was labeled "battery disconnected" & "battery connected"? As it is, it's sort of like saying, you can't put to much water in the cooling system of the nuclear reactor. :-)
Hunter & SweetC
battery, battery disconnect
