Old 04-18-2016, 11:16 PM   #11
I have a hunch that the disconnect switch only turns off the inverter. Turn off the disconnect and see if the fridge light goes out.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-20-2016, 12:36 PM   #12
I really don't know.
Rdsmith281 is offline   Reply With Quote
Old 04-20-2016, 12:49 PM   #13
Turn off the disconnect and check the fridge light. If the fridge light is not on then the disconnect is just for the inverter and not the whole trailer.
2007 Surveyor SV230
Old 04-20-2016, 12:55 PM   #14
Should the fridge light be on? I'm not plugged in.
Old 04-20-2016, 12:57 PM   #15
TURBS's Avatar
Yes it's running on the battery.
Old 04-20-2016, 01:04 PM   #16
Ok, I'll check it out.
Thanks for the quick response.
If I determine the disconnect switch is for the inverter only, is this normal? I was under the impression that the disconnect switch turns off all 12 volt applications.
Old 04-20-2016, 01:05 PM   #17
TURBS's Avatar
If it is I'd add another for other battery.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-20-2016, 01:40 PM   #18
Thanks for everyone's responses.
Old 04-20-2016, 02:23 PM   #19
You're welcome !
Let us know what you discover.
2007 Surveyor SV230
Old 04-20-2016, 08:59 PM   #20
I discovered it goes to the inverter, just as you mentioned. Thanks. i'm definitely going to install a disconnect switch to the other battery. Thanks again.
battery, battery disconnect
