Old 09-18-2015, 05:18 PM   #1
Night Stone's Avatar
Battery Disconnect switch
Can anyone tell me if this was installed properly? I am thinking there should be a wire to the positive terminal?
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 09-18-2015, 05:50 PM   #2
PokerDealer's Avatar
All I know is that cut off switches are supposed to be run ONLY on the negative side, as far away from spark as possible. My original thought was it must disrupt the positive power, I was incorrect. All I've seen are for the grounded side.
PokerDealer is offline   Reply With Quote
Old 09-18-2015, 06:29 PM   #3
If I understand that picture correctly, I don't believe that it will accomplish anything. It may/may not be wired correctly, but it looks like there's another ground to the frame independent from your disconnect switch. The makes the disconnect redundant and ineffective.
bruceatlam is offline   Reply With Quote
Old 09-18-2015, 06:32 PM   #4
BendOrLarry's Avatar
No way to tell from that picture.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
battery, battery disconnect
