Old 05-19-2014, 11:24 PM   #1
Battery disconnect switch - in or out?
I have a Rockwood 8325 Travel Trailer. Regarding the Battery Disconnect Switch:
1 - Which is on and which is off - in or out??
2 - When I pull it out I hear a humming noise like a fan (I'm plugged into city power). I also hear that noise if my outside lights are on. Is that normal?
3 - What position should it be in when I'm driving?
4 - What position should it be when I'm plugged into city power?
5 - Just had a mighty thunder/lightening storm and the power went out in the park and I had no lights - at all! I thought the overhead lights were on 12v. Shouldn't they have come on? Maybe I had the Disconnect in the wrong position....whatever "wrong" is - I have no clue.
The "manual" sucks - does anyone know of any other documentation available? electrical system, schematic, etc.
Thanks!!!!
GVJeeper is offline   Reply With Quote
Old 05-20-2014, 12:26 AM   #2
rsibarra2010's Avatar
I believe there's a simple way to check. Unplug from shore power and pull the switch. If the lights are off then pulled out is the disconnect.
rsibarra2010 is offline   Reply With Quote
Old 05-20-2014, 06:02 AM   #3
Todouble's Avatar
Mine is pull out=ON
Push in=OFF
Todouble is offline   Reply With Quote
Old 05-20-2014, 06:40 AM   #4
Dave Lyon's Avatar
Originally Posted by Todouble View Post
Mine is pull out=ON
Push in=OFF
X2
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 05-20-2014, 06:43 AM   #5
Mine is pull out=ON
Push in=OFF
Same here I wish it was the other way around though.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 05-20-2014, 11:59 AM   #6
Mine is pull out=ON
Push in=OFF
OK - the battery is ON when I pull it out. The fan is running - does it run all the time?
Let's see if I have it right: When I'm parked and plugged into shore power, if I leave it pulled out (on) it will charge my house batteries. When they are charged I can push it in (off) and keep a eye on my gauge to be sure to charge it back up as needed.
Last night the power when off I needed to pull it out (on) to get juice to my 12v overhead lights. Right?
Sorry I seem so stupid but I had a minor stroke a few years ago - this is the kind of thinking that makes my thinking get a little confused. If it's called a "disconnect" but when it's "on" when pulled "out" , to me "on" means it's disconnected because the "disconnect" is "on" - that's all bass-awkwards to me. They should call it a battery "connect" switch....when it's on, the batteries are connected.
Thanks!!
Old 05-20-2014, 12:17 PM   #7
You really only need to push it in to disconnect your battery when not in use for a long period of time...like winterizing...or you don't use it for a few weeks and you don't keep it plugged...then you disconnect the battery to prevent it to drain it's power.
I leave mine pulled out all the time since I'm camping every weekend.
Black
Black is offline   Reply With Quote
Old 05-20-2014, 02:08 PM   #8
What Black says is spot on. The fan you are hearing is probably your inverter charging your battery. It will shut down once it recharges your battery. If I am not mistaken you need your battery on to use lights as they are 12 volt.
battery, battery disconnect
