Old 08-05-2016, 11:08 PM   #1
MNtraveler's Avatar
Battery disconnect switch issue
A funny thing happened when I installed a disconnect switch today. After adding it, I disconnected it (unscrewed the disconnect screw) and turned on the main battery switch to confirm all was off, and the vent fan went on (it was on when I turned the power off). Also the cab radio had come on. I think what is happening is that the wire connecting the two ground terminals is still connected to the coach ground wire even when the battery is disconnected, so it's running off the one battery. (See pictures of setup below.) So do I need TWO battery disconnect switches to completely shut off all power while in storage? Or should I attach the ground terminal connector wire to the battery side of the disconnect switch so it doesn't touch the coach ground wire?
PS: in case my footer doesn't show, it's a 2016 Forester 2401R MBS.
Name:	ImageUploadedByForest River Forums1470452797.632567.jpg
Name:	ImageUploadedByForest River Forums1470452813.750017.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 08-06-2016, 09:46 AM   #2
please get a second opinion on this. but it looks to me as if the battery disconnect still allows current to flow from the other battery. look at the disconnect. on the side that gets disconnected there are two cables attached. one is the jumper to the second battery and the other goes to the loads. if you open the disconnect power could still flow from the second battery to the disconnected part of the disconnect where it joins with the cable to the loads. this is a complete circuit. I think you should move the jumper between the two negative battery terminals off the disconnect and place it directly on the battery terminal. that way only to load cable will be on the disconnect side. and when it is disconnected, both batteries will be disconnected from the load.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 08-06-2016, 10:38 AM   #3
You don't need a second disconnect switch. You need to move the black wire from your second battery to the other side of the disconnect. You should only have one wire on the side away from the battery. If the post is not long enough you can buy an adapter to go on the round battery post to hook up to.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-06-2016, 10:47 AM   #4
X2, tried to edit my post but some how I deleted it... Good catch happy vibe..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 08-06-2016, 10:52 AM   #5
MNtraveler's Avatar
Thanks guys! Makes sense.
2016 Forester 2401R
Old 08-06-2016, 02:49 PM   #6
padcarroll
Excuse my ignorance but why is the disconnect on the negative side? My class A disconnects are on the positive terminal.
Dave and Pam Carroll
Callie - 8 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 08-06-2016, 02:52 PM   #7
NMWildcat's Avatar
Either way works. Most folks prefer the negative side due to simplicity I believe.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-06-2016, 02:54 PM   #8
dieselguy's Avatar
There are two schools of thought on battery disconnects ... each side is pretty passionate about the issue. Either way gets the job done ... I prefer disconnecting the negative.
dieselguy is offline   Reply With Quote
Old 08-06-2016, 05:56 PM   #9
MNtraveler's Avatar
Either side can be d/c'd, but it's generally safer to work on the ground side. Less sparking, and if you accidentally short something to ground it makes no difference. Whereas on the hot side you can weld your open end wrench to the frame.
Old 08-06-2016, 06:41 PM   #10
camaraderie's Avatar
Yes...additionally the + and - post terminals are different sizes and the disconnects for POSTS are made to fit the negative side...do NOT try to pound them on to a positive post!
There's also usully a bunch of positive wires vs a couple of negative ones...to it is easier to deal from the negative side as well.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
battery, battery disconnect, switch
