Old 02-19-2014, 09:41 AM   #1
battery drain
I have a problem with my battery going down while hooked up to electrical. I have to put charger on battery
porter lizard is offline   Reply With Quote
Old 02-19-2014, 09:45 AM   #2
TURBS's Avatar
Sounds like your converter isn't working an inline fuse or the 110v breaker.
You need a volt ohm meter to diagnose.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-21-2014, 05:17 PM   #3
Check the voltage at the battery while unplugged and then again when plugged in. Should see at least 13.5VDC when plugged in.
cadman99 is offline   Reply With Quote
Old 02-21-2014, 05:24 PM   #4
Herk7769's Avatar
There are TWO resettable current limiters (fuses) between the converter and your battery. They are as pictured.
One should be very close to your battery (a few inches to a foot) and the second located at the junction box for your tow vehicle umbilical cord.
Look at the narrow side for a small button and make sure it is "IN"; if it is "OUT" and won't reset you have a short somewhere.
Look under the frame of travel trailers and under the pin box of 5th wheels.
They may (should) have a red plastic cover.
ID:	46572   Click image for larger version
Name:	NO POWER to 12 VDC.jpg
ID:	46573   Click image for larger version
ID:	46574   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
battery, drain
