Old 06-02-2016, 05:01 PM   #31
Learning a lot as I go...
Originally Posted by Missdenise View Post
Fridge is not in a slideout.
What could be done about the heat strip if that is the problem? There is no switch of any kind.
Thanks!
Originally Posted by Flybob View Post
There is a connection on the control board that it is powered from. If you remove connection it will turn off heat strip. If you alternate between boondocking and connected camping you could extend the wire and add a switch. I will try to find control board photo showing connection.
YMMV depending on how old your unit is...
In my 2015/2016 Dometic the "heat strip" as it is called is plugged into a circuit board which is part of the fridge compartment light housing. This housing will have the switch sticking out the front and be held onto the top of the compartment by 2 screws. If you remove the screws and take it down there will be two wire connector blocks: one with 4 wires and another with 2 wires. Just disconnect the 2 wire and you should have disabled the heat strip.
stevejahr is offline   Reply With Quote
Old 06-02-2016, 05:04 PM   #32
Originally Posted by flymhi View Post
Read this thread.
I will read the whole thread.
Missdenise is offline   Reply With Quote
Old 06-02-2016, 06:16 PM   #33
I had this problem, there is a 5A fuse running the heater! You need to pull it off the board, mine was on the outside of the trailer under fridge cover. Solved the problem!
2016 Rockwood Ultra Lite 2604WS
2004 Dodge Ram 2500 CTD 5 speed Manual 4x4 Laramie
2005 Ford Mustang Convertible
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 06-02-2016, 06:43 PM   #34
I hope it is as simple as that. I saw you had the same problem but didn't see the solution. I sent you a PM, I guess you didn't see it.
We have the same camper - 2604WS but mine is a 2015. I will look for this fuse tomorrow.
Thanks everyone.
Old 06-02-2016, 08:58 PM   #35
camaraderie's Avatar
Since you're heading back tomorrow...may I suggest that before you do anything else...your hubby puts a volt meter on the battery terminals and read the voltage. Anything less than 12.0V should be cause for concern and confirmation that you have a significant drain on your battery even with the trailer disconnect switch engaged.
Once you know your starting voltage point...you can plug in the camper and check all the other stuff that has been discussed above.
BTW many folks don't have an clamp meter in their toolbox and it is a very useful thing to have around to check all things electrical...AC &DC on the RV and at home. Here's a nice inexpensive one from Amazon which comes complete with instructions (in English - LOL) http://www.amazon.com/Uni-T-UT204-Au...mp+clamp+meter
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-02-2016, 11:56 PM   #36
Thanks everyone.
Same trailer I have, see my earlier response where you can disconnect the cable heater without losing any other functions of the fridge. Removing the fuse will disable more than just the heater strip.
Note the heater strip is ~50 ohms and will pull about 1/4 amp as long as the fridge is turned on.
Old 06-03-2016, 12:30 AM   #37
flymhi's Avatar
Steve do you have a DM2652?
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 06-03-2016, 07:40 AM   #38
Thanks everyone.
Sorry I didn't see a PM from you I will look for it. You can find the fuse in the schematic in the trailer manual. It will stop the heater and also the light in the fridge. Now I have no battery draining issues at all, love my trailer!
battery, drain
