Old 04-21-2011, 06:06 PM   #21
jimh's Avatar
Originally Posted by SoMoney View Post
The dealer checked it out and one of my batteries was bad. I asked if I could pay the diff for a bigger battery that would fit the tray. I didnt pay anything when I left so when I popped the battery door I see they replaced them with the cheap o' 27's
2 x INTERSTATE SRM-27's.
600CCA
750MCA
160m@25A
17h@5A
5.2h@15A
I suspect wiring the steps DIRECT TO BATTERY is a dealer trick to allow the coach to sit on a lot with BCC Off yet keep the steps running for sales prospects. I'm wiring everything to the BCC (The 30A and the 12A). OFF should be "OFF"... The Steps work with or without the green wire touching the negative pole so I'll relocate that ground wire to frame.
ur probably right. that may have contributed to a premature battery failure as well. (and a lot of frustration tracing it down). glad the problem is solved.
jimh is offline   Reply With Quote
Old 04-21-2011, 08:41 PM   #22
SoMoney's Avatar
Originally Posted by herk7769 View Post
An excellent Dual Purpose Battery.
Yes they are great dual purpose, yet I have a battery up front for starting.. I'm going TEST dry camp tomorrow (Water Heater/pump, and the exhaust fan set to a comfortable 73deg), and see how long it takes that batts to read 50%.
SoMoney is offline   Reply With Quote
Old 04-21-2011, 08:46 PM   #23
Herk7769's Avatar
I would love to know. My fully charged 2 battery 150 AH bank was run down to 50% in a week of sitting in the dealer's lot while they worked on it with everything off but the propane detector, if that helps.
HAM CALLSIGN - KC3FFW
battery
